Go to Post Are we really that close-minded that we have to insult other teams that deviate from what we percieve to be right? Giving an opinion and insulting someone are far from each other. - Amanda Morrison [more]
Unread 07-16-2007, 12:53 AM
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: pic: Planetary Transmission
Originally Posted by Gdeaver View Post
I believe that the denso worm gear would see relatively little torque because it is just modifying one part of the planetary gear train that is normally stationary. Precession and procession modify the gear ratio. Can you show the exploded view of the planetaries?
Pause for a second and consider what usually keeps some part of a tranny stationary. It's usually metal. If the wheels are stalled, the sun is under torque. In fact, you should be able to figure that torque out pretty easily. Work your CIM stall torque forward to the axle, and then backward to the sun. Assuming your power takeoff is on the planet holder, the ratio should be (Outer ring/CIM pinion)*(Sun/Inner Ring) * CIM Stall * 2. I have a feeling the first bit is going to be around 1. Possibly greater than one. So you're looking at twice the CIM stall torque being applied to your ND drive shaft. Plus, even worse, shock loads. I'd actually be very worried about this, really.
pic: 379's transmission Robo_Cat_379 Extra Discussion 10 03-05-2007 08:48 AM
pic: 2 Speed Transmission AustinSchuh Extra Discussion 20 12-30-2006 04:39 PM
pic: 2 speed transmission 1 psyco_klown Extra Discussion 3 09-05-2006 07:03 PM
pic: 2 speed transmission 2 psyco_klown Extra Discussion 0 05-22-2006 01:35 PM
pic: lego Planitary... Kinda CD47-Bot Extra Discussion 5 07-14-2003 11:55 PM
