Go to Post Right now, it drives around....hopefully tomorrow it will do a LOT more! - MrForbes [more]
Unread 07-16-2007, 11:13 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Planetary Transmission
Originally Posted by Paul Copioli View Post
1. You do not get ANY added output torque from the ring gear motor ... zero, nada, nothing. The ring gear has to react against the input torque of the sun gear and adds nothing to the output torque.
4. When designing your gear ratio's, there are three basic areas that the CCT gives you: Ring gear in reverse, ring gear at 0, and ring gear forward. Design your normal operating conditions at ring gear at 0 speed.
It looks like Alex has designed his system "inside out" from the way you expect. If I'm reading the drawing correctly, the dual CIMs drive the ring gear, and the "variable" part is due to rotating the sun gear.
pic: 379's transmission Robo_Cat_379 Extra Discussion 10 03-05-2007 08:48 AM
pic: 2 Speed Transmission AustinSchuh Extra Discussion 20 12-30-2006 04:39 PM
pic: 2 speed transmission 1 psyco_klown Extra Discussion 3 09-05-2006 07:03 PM
pic: 2 speed transmission 2 psyco_klown Extra Discussion 0 05-22-2006 01:35 PM
pic: lego Planitary... Kinda CD47-Bot Extra Discussion 5 07-14-2003 11:55 PM
