Go to Post Well, it worked in inventor . . . - Chris Fultz [more]
Unread 27-07-2007, 22:22
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
Re: pic: Custom Machined Aluminum #25 Sprocket
Yes, the teeth were milled. Off the top of my head, I believe these are the operations we performed. It was a couple of months ago so the feeds and speeds might not be 100% accurate.
5/8" roughing endmill 1000rpm 4"/min roughs out tooth face and bore
1/2" ball nose endmill 1200rpm 2"/min put radius' around bolt holes
1/4" roughing endmill 1800rpm 2"/min roughs out medium sized pockets
1/4" plain endmill 2000rpm 6"/min finishes medium sized pockets and bearing bore.
1/8" plain endmill 2500rpm 1.25"/min mills small pockets, spot drills bolt holes, and outside sprocket teeth.
CAD files are available for anyone who wants them. As for FEA, if anyone wants to do it, go nuts.
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
pic: MVRT1115 small machined parts Ashwin Extra Discussion 5 23-02-2007 13:22
pic: 254/968 Machined Parts Cory Robot Showcase 11 12-02-2007 07:42
pic: Team 1538's Machined Parts (C) Jon Jack Extra Discussion 19 23-01-2007 02:06
pic: 1538's Machined Parts (B) Jon Jack Extra Discussion 2 21-01-2007 20:31
#25 Aluminum Sprocket Source Don Wright Kit & Additional Hardware 1 26-01-2005 13:41
