Go to Post Whether or not your team has the technical mentors, as long as your kids are still inspired by the adult technical mentors of other teams, and get the picture that we're trying to portray in this program, the best that you can do is the best you can do. Do it, and be proud of your results. - Beth Sweet [more]
Unread 05-08-2007, 21:23
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
Re: pic: summer project coming along...
Looks great. Looking at your vidio it looks like the pivot low for the handle will make it hard to ballance, if you could make it go forward and back with rotating handle grips that would alow you to lock down the lower pivot point making it easier to ballance it when you drive. With the drive set up it is going to be fast so hold on. check ours out at http://team1322.org/joeway.htm we used caster for ballance. Good luck. Looks like fun.
pic: Omnitrack Summer Project? Gabe Technical Discussion 27 07-09-2006 00:28
pic: Rage coming along TriggsJr Robot Showcase 4 14-02-2006 15:35
All-Time PID Drive with Hall-effects: Coming along very nicely jdong Programming 6 05-02-2005 19:39
summer coming... need job!!! btw, who's coming to Berkeley? archiver 2001 0 24-06-2002 03:46
How's everyones robot coming along??? archiver 2001 4 24-06-2002 00:01
