Go to Post Off-season events aren't just for gameplay, they should also be a training session for new students and rookie teams. - Bill Moore [more]
Unread 12-09-2007, 13:00
newton418's Avatar
newton418 newton418 is offline
AKA: Ryan Newton
FRC #0418 (Purple Haze)
newton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to all
Re: pic: DeWalt drive base
118 Ran four small CIMs and two FPs into one dewalt this season.
I got to talk to some of the guys from 118 at LSR last season. They told me they'd had some problems with the gears in the DeWalt shattering, but I don't know exactly why this occured, or how frequent it was. Also, I remember them having several backup V6's. Nonetheless, they definitely proved that it can be done. Hopefully one of the guys that worked on the '07 118 drive train could fill us in on what they found out about the DeWalts.
Originally Posted by Qbranch View Post
I'm not a big time drivetrain guy... but can a DeWalt transmission take the torque of two CIM motors? Perhaps you could combine their torque before going in to the transmission?
Or, to avoid the 'losing half the transmission and stripping them out' problem if one shifts and the other doesnt (or other reasons why one might sease) can't you just turn the torque clutch down on the drill to a reasonable number so that in case you start to backdrive the transmission too hard it just slips? I don't know how much torque the clutches go up to in those things before they go direct drive, just a thought.
-q
The DeWalts have been shown to handle the torque of two CIMs, but since only a few teams have done it, we don't have much information on how well they hold up. So many teams have followed the whitepaper and have never touched their DeWalts after that, and that reliability is part of what makes the DeWalts so valuable. Also, in dbell's design he's keeping the first stage of planetary gears, so there's already 3 times more torque on the transmission than what most people have used.
As for the torque clutch, it's typically removed with the CIM configuration, since we remove the first stage of planetary gears. Since this design is keeping those, I'm not sure if he's going to keep the clutch or not. Either way, in a high torque application (like the drive train), you probably wouldn't want to mechanically limit your power unless you really knew what you were doing.
dbell - are you planning on keeping the clutches? If so, you should read this: http://www.chiefdelphi.com/media/papers/1680. They kept the clutch in and found that it bent after a couple of matches, causing them to service the transmission frequently. If you aren't going to keep them, how are you going to keep the first ring gear in place?
Team 418 Purple Haze
http://www.lasarobotics.org/
pic: DeWalt drive base: side module dbell Extra Discussion 22 09-07-2007 19:11
pic: 1270's 8 wheel drive base redbarron Robot Showcase 9 12-02-2007 06:15
pic: Dual sprocket Dewalt drive Andy Brockway Extra Discussion 4 05-12-2006 08:05
pic: 195 Drive Base Tom Bottiglieri Robot Showcase 24 16-02-2006 12:50
pic: 1083 drive base CD47-Bot Robot Showcase 11 24-02-2004 14:04
