Go to Post But sometimes you just wanna build something that's MFD. - Andrew Schreiber [more]
Unread 16-09-2007, 19:27
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
Re: pic: DeWalt drive base
If you can't keep that stage, it wouldn't be too much extra work to move each dewalt inward, and have a sprocket reduction to the outer wheel. Then keep the center wheel connected in the same fashion.
Keep refining this until it is 100% ready for production, it will save your team a lot of time.
It might save time.
This would be a possibility, but a significant change to my current design. But part of me wants to try using the extra stage. If it works it could be great. Using a chain reduction would a significant amount of weight and space.
I'm not a big time drivetrain guy... but can a DeWalt transmission take the torque of two CIM motors? Perhaps you could combine their torque before going in to the transmission?
The DeWalts would almost certainly be strong enough. But it would give up these advantages of my current design:
-weight balance of CIMS
-if any chain were to break, only one wheel would lose power
-does not require an extra gearbox to gear the 2 cims together
dbell - are you planning on keeping the clutches? If so, you should read this: http://www.chiefdelphi.com/media/papers/1680. They kept the clutch in and found that it bent after a couple of matches, causing them to service the transmission frequently. If you aren't going to keep them, how are you going to keep the first ring gear in place?
I am not planning on using the clutches. I'm not sure what you mean by "how are you going to keep the first ring gear in place?"
DB
pic: DeWalt drive base: side module dbell Extra Discussion 22 09-07-2007 19:11
pic: 1270's 8 wheel drive base redbarron Robot Showcase 9 12-02-2007 06:15
pic: Dual sprocket Dewalt drive Andy Brockway Extra Discussion 4 05-12-2006 08:05
pic: 195 Drive Base Tom Bottiglieri Robot Showcase 24 16-02-2006 12:50
pic: 1083 drive base CD47-Bot Robot Showcase 11 24-02-2004 14:04
