Go to Post FIRST doesn't end after your last year within a team. It's never going to end. - Tetraman [more]
Unread 17-09-2007, 19:31
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Re: pic: Team 540 Air Cannon
Originally Posted by Qbranch View Post
I tried to cut the plastic out for use as a pressure vessel and just use it as a barrel... then use 1~2 of the craftsman pressure tanks instead, and manifold them together (if i use two) to increase the flow rate (they have a single 1/2" port)
However, i keep having trouble figuring out what kind of threads go with what.. NPT, NPTF, BSPT, I seem to go in circles and get confused.
Anybody out there good with pipe threads?
-q
Tanks usually (99.9%) come with NPT threads so NPT or NPTF fittings will work with them. FYI NPT & NPTF threads are interchangeable with use of PTFE tape.
Finding fittings that use BSPT threads in the US might be a problem.
Finally my apprenticeship years as a pipe fitter/ boiler operator come in handy here
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
Air Cannon Rob2713g General Forum 40 27-05-2009 21:15
pic: Toltech Air Cannon Prototype Andrew Schuetze Extra Discussion 2 29-05-2007 15:29
air cannon Evil Asian General Forum 10 15-03-2007 10:31
pic: air cannon cjreyda Extra Discussion 6 09-11-2006 12:05
Air Cannon Michael223 Technical Discussion 13 14-06-2006 10:23
