Go to Post Give me more tools; I’ll use the ones that are most useful for the job. - Natchez [more]
Unread 18-09-2007, 17:10
newton418's Avatar
newton418 newton418 is offline
AKA: Ryan Newton
FRC #0418 (Purple Haze)
newton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to all
Re: pic: DeWalt drive base
I am not planning on using the clutches. I'm not sure what you mean by "how are you going to keep the first ring gear in place?"
DB
I didn't spend time trying to figure out exactly how the clutch works, but from what I remember it seems to me like the first ring gear in the DeWalt transmissions are kept in place by the clutch. When too much torque is applied to the transmission, the clutch gives in, allowing the first ring gear to slip. If you plan on using the first gear, but you are going to remove the clutch, there is nothing stopping the first ring gear from spinning freely. Thus, you would need to secure the first ring gear in place.
Team 418 Purple Haze
http://www.lasarobotics.org/
pic: DeWalt drive base: side module dbell Extra Discussion 22 09-07-2007 19:11
pic: 1270's 8 wheel drive base redbarron Robot Showcase 9 12-02-2007 06:15
pic: Dual sprocket Dewalt drive Andy Brockway Extra Discussion 4 05-12-2006 08:05
pic: 195 Drive Base Tom Bottiglieri Robot Showcase 24 16-02-2006 12:50
pic: 1083 drive base CD47-Bot Robot Showcase 11 24-02-2004 14:04
