Go to Post I was dragged to the first team meeting in September my freshman year and a week later, found myself at Fall Classic. Needless to say, after experiencing the heat of a competition, I was in love. ... Robotics has become far more than just that. I get to do the coolest thing in the world. - Audrey Chu [more]
Unread 09-19-2007, 02:44 AM
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: pic: AM Mecanum Chain Drive
I got to see (and drive!) the base the night the team got it mostly put together, so I may be able to answer some of the questions...
Originally Posted by techtiger1 View Post
Well I will say if your going to do mechanum's this looks like an easy and efficient way to do it. Did you guys modify the am single speeds at all for weight or anything? Ohh I'd like to know how the rollers held up.
-Drew
The transmissions weren't modified as far as I know; they just had longer bolts put through two of the holes to hold it on and together. The tensioner is just a nylon washer that is on the slot-mounted bolt. The chain is tensioned by tilting the transmissions back or forth.
Originally Posted by AdamHeard
Is that an I beam as the frame?
Yep, fiberglass I beam. It has been used as the side rails for all of our robots to date; it's super strong and very easy to mount things to. (see here: http://www.chiefdelphi.com/media/photos/26813 )
Originally Posted by Lil' Lavery
What made you opt to link an AM single speed via chain rather than direct driving (or reducing) a Banebots transmission, which seems like it could be a cheaper, lighter, and more compact (in 2 of the 3 dimensions) solution. Don't really see the need to torque up a mecanum system, especially on a promobot.
Although I do very much like how well the system fits together (with the AM tucked in the frame and the CIM poking over the top), and I also like the use of channel (i-beam?) for the frame railing.
I believe that we already had the AM singlespeeds on hand from previous experiments, so it was the cheaper route. Also, the chain reduction isn't for more torque; it's to make the bot drive slower.
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 12-20-2006 11:07 PM
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 03-29-2006 10:16 PM
Chain Drive chain Damelvin 3D Animation and Competition 2 02-15-2005 12:19 AM
Chain Drive Question Matt_Kaplan1902 Technical Discussion 34 04-12-2004 02:21 PM
Direct drive or Chain? Suneet Technical Discussion 32 03-27-2003 11:00 PM
