Go to Post Whoooo, just got my wheels from AM! Sometimes it's cool to live in Indiana. - IndySam [more]
Unread 11-09-2007, 18:59
pic: 294 - This is How we cut (wire EDM)
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: pic: 294 - This is How we cut (wire EDM)
Could you explain what Wire EDM is and how and why it is used please?
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 11-09-2007, 19:03
They can cut any shape as it is wire (very, very thin) that does the cutting with electricity.
Team 195 cut their wheels with one.
We've used it to cut keyways, odd sized hex holes, strange hubs (5mm w/ 4.5mm flat), etc...
Unread 11-09-2007, 19:28
Dan Petrovic's Avatar
FRC #0166 (Chop Shop)
The best description I can give is that it's like a waterjet.
Although, from what I've heard, EDMs leave a cleaner edge than waterjets.
Unread 11-09-2007, 21:09
DonRotolo's Avatar
Back to humble
FRC #0832
Think of it as a very small wire, and sparks are made to jump from the tip of thr wire to whatever metal workpiece you want to shape. The sparks vaporize a tiny amount of the metal workpiece, and if you do it often enough you spark a hole into the workpiece. Now, control the spark and wire tip position very precisely, and you can shape some really complex shapes. Unlike a waterjet, you don't have to cut all the way through.
EDM - Electical Discharge Machining.
Don
Unread 11-09-2007, 21:14
Don
Well... for the machines we have that is halfway correct.
We have a wire EDM which has a wire that goes through the part and cuts profiles.
The other is called a "Sinker" (I think) which as a shaped electrode (like a hex shaft) that when pushed into the piece, takes of .003 at a time. This doesn't have to go all the way through.
Unread 11-09-2007, 22:31
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
as well as leaving a cleaner finish, they can machine much smaller radii, and can hold much closer tolerances.
2001-2004: Team 100
2006-Present: Team 254
Unread 12-09-2007, 11:23
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Things that describe a wire EDM machine:
>Swiss-Watch Accurate
>Cuts things you can't cut any other way
>Slower than Molasses on the dark side of the moon in january. (Rough your parts with a standard CNC machine first if possible, or wait a day or so)
>Smoky
If you can...
>See if you can use a contact EDM machine (carbon/graphite shaped electrodes) which cut faster.
They make cool stuff... but see if you can make it another way first! (Broaching, etc.)
-q
Electrical Engineer Illini
Unread 12-09-2007, 16:35
EricH EricH is offline
>Smoky
Add down when you need them and that's the lot, I think. This machine was down for some reason in February--and both 330 and 294 needed to put a keyway in a sprocket right at the end of build! (ECC didn't have the right size broach at the time. They got one a week or so later.)
Unread 12-09-2007, 19:37
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
>Smoky
If you can...
-q
Adding to this:
> it can cut through very thick metal - I have seen as much as 4 inches, but very slowly
> it can make a tapered cut from the top to the bottom through the metal thickness
Both of these come in handy for making molds and punch press tools.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 05-10-2007, 22:00
Chief Pride's Avatar
Chief Pride Chief Pride is offline
<3
AKA: James Kiefer
Chief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond repute
YOU HAVE A WIRE EDM???
im so jelous
Unread 06-10-2007, 00:37
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
The EDM is an amazing tool, we used one last year for getting a coupler done for the window motor, and it turned out great.
pic: 294 - This is How we cut (CNC lathe) AdamHeard Extra Discussion 5 14-10-2007 22:32
pic: 294 - This is How we cut (HASS) AdamHeard Extra Discussion 4 10-09-2007 08:02
pic: IFI: This is how we cut. JVN Extra Discussion 15 06-03-2006 13:21
pic: NEMO: This is how we cut KathieK Extra Discussion 2 17-02-2006 03:50
pic: This is how we cut kap18512 Robot Showcase 3 12-02-2006 14:28
