Go to Post Good luck, and may the FIRST be with you. - Leav [more]
Unread 09-10-2007, 20:18
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Re: pic: Our new cart, pic 1
Guys, have faith in our engineering skills. The cart is a completely self sufficient electrical and mechanical system that can stay active for a full day with the drive system being used and 2 days of just charging batteries (without needing a recharge). Every system has a redundant system to back it up in case of a failure. The system is charged by one AC input to a custom designed distribution box using relays to select shore power or inverter power. It has a descent speed and a relatively tight turning radius. It is very safe for the user as well as the surrounding people. For the driver it has a 4 point restraint system and for other people the cart has an emergency braking system that brings it to a stop within inches.
As for the magnetic shore power plug, that would be very unsafe, because when the magnet disconnects you now have a situation where the leads can be easily shorted, or shock someone.
Championship - Delphi "Driving Tomorrows Technology"
pic: Our New Team. Michelle Celio Extra Discussion 2 07-09-2007 10:11
pic: 1029 cart - Rene de Cart bjimster1 Extra Discussion 6 03-03-2007 20:47
pic: Finally, our new milling machine Mark McLeod Extra Discussion 11 23-09-2006 18:30
pic: Our New T-Shirt Design!!! Nathan Pell Extra Discussion 19 10-01-2005 00:10
pic: Our new robot CD47-Bot Robot Showcase 3 20-01-2004 00:01
