Go to Post If you want to have other teams cheer for you all day long at competition, name your team "Robot Coming Through". - Gary Dillard [more]
Unread 25-10-2007, 22:51
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: pic: Cart Wiring Plans
Originally Posted by BlackShadowFox View Post
... Please Explain
I'll take a whack at it.
First, the trickle chargers must be UL rated if they are active while the cart is connected to AC power. And they should be appropriately fused to protect the wiring to the cart battery. Since Chargers 2 and 3 effectively become trickle chargers when their batteries are full, separate trickle chargers aren't really needed anyway. Chargers 2 and 3 should be connected to AC power when it is available, and switched over the inverter output when AC power is not available.
Second, the connection shown as a red line across the top center of the diagram indicates direct connection of the inverter output to an AC power cord. This is generally not a good idea, and in any case it provides no benefit to your cart that I can see. Powering the inverter from the cart battery and then powering Charger 1 from the inverter to charge the cart battery -- well, that arrangement has power chasing its own tail! The inverter should provide power to AC devices when AC power connection is not available, and should not be connected to Charger 1.
Richard Wallace
since 2003
pic: 1029 cart - Rene de Cart bjimster1 Extra Discussion 6 03-03-2007 20:47
pic: 1902's $25 Cart Andrew Rudolph Extra Discussion 6 26-03-2006 23:19
pic: 1345's Cart Arefin Bari Extra Discussion 12 04-03-2006 09:56
pic: Cart CD47-Bot Extra Discussion 6 14-03-2004 00:24
pic: Team 548 Cart CD47-Bot Robot Showcase 19 07-04-2003 18:37
