Go to Post You have the right to remain silent. Anything you say can AND WILL be held against you (AND YOUR TEAM) in the court of public opinion. So choose what you do wisely. - Koko Ed [more]
  #91   Spotlight this post!
Unread 21-10-2007, 22:39
ctorloey ctorloey is offline
AKA: Dave Luongo
FRC #1153 (Roborebels)
ctorloey has a spectacular aura aboutctorloey has a spectacular aura about
Re: White Paper Discuss: Nothing But Dewalts
I was wondering how the dewalts worked on the programing side of things? having the robots switch speeds during the matches, was that complicated for the programmers to solve? Or was it easy to program.
  #92   Spotlight this post!
Unread 27-10-2007, 15:20
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
I've read over the white paper and the various other threads on the subject with regards to slight modifications. What I hadn't noticed was if anyone had come up with a design or modification to allow these excellent transmissions to work with the Mini Bike (aka large) CIM.
If so, I'd like to hear more about it or discuss it.
It's something that might be worth pursuing.
Thanks
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
  #93   Spotlight this post!
Unread 27-10-2007, 15:55
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
Phalanx,
Yes we converted the big cim last year when the season was over, we built two of them and put them on a chassis.They were really slow. They would be good for an arm but they are really heavy. I would not use these motors in the DeWalt form, I guess I would not trust them, just my opinion.
-Josh Murphy-
  #94   Spotlight this post!
Unread 27-10-2007, 16:16
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
Rookie Year: 1997
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
As Josh indicated - without attempting to modify the gearing in the dewalt - the big CIM ran pretty slow. Unless the application was appropriate, I wouldn't use them.
If they were adapted to the proper gear box they could work as well as the other size CIM. Although, it might be easier to drive through an external gear box, to get what you need out of them.
So, if you wanted a big heavy motor that would work all day long, without over heating - and you had the weight available - the big CIM's could probably be adapted.
  #95   Spotlight this post!
Unread 27-10-2007, 16:47
Team 33 used A big CIM with a dewalt for drive in 2006. Iirc, it worked out pretty well.
  #96   Spotlight this post!
Unread 27-10-2007, 17:59
Phalanx's Avatar
I should have put this in my previous post, but alas hindsight is always 20/20.
I never had any intention of using the Dewalt transmission with the BIG CIM for a base drive. The thought was as others have pointed out, that perhaps it would be suitable for an arm or turret etc...
Odd are it might be, but it may not be worth it, there might be better choices.
Thanks for the feedback and exploring my thoughts.
  #97   Spotlight this post!
Unread 14-11-2007, 14:22
FTtyler's Avatar
FTtyler FTtyler is offline
FRC #1561 (Purple Ducks)
FTtyler is an unknown quantity at this point
I have a couple quick Questions.
Has anyone had problems removing the chuck off the end of the drill?
And How did you end up getting it off?
We are having problems with it and we need some help!
  #98   Spotlight this post!
Unread 14-11-2007, 14:56
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Yes, we had trouble. Ended up using heat and impulsive force; i.e., torch, punch, and hammer. That loosened the (left) threads so we could get the chuck off. The trick is using just enough heat and impulsive force to get the job done, and not enough to break things. We had a very experienced tech-ed teacher lead the students through the exercise.
Richard Wallace
since 2003
  #99   Spotlight this post!
Unread 14-11-2007, 16:35
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
There is screw that must be undone that is inside the chuck. I believe that it is reverse threaded. To get the rest of the chuck off, we used a socket wrench with a long lever attached to it. To interface the wrench with the chuck we used a hex adapter (something that fits in the socket and is hex-shaped at the other end). The adapter also needs to fit into the chuck. Tighten the chuck around the adapter and use the wrench to carefully unscrew the chuck.
Hope that wasn't too confusing...
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
  #100   Spotlight this post!
Unread 15-11-2007, 06:49
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
It is easier and cheaper to order individual parts as per the NBD White Papers.
Dewalt has a great website http://www.dewaltservicenet.com
And YES they can be shifted with a simple servo.
Mike Martus
  #101   Spotlight this post!
Unread 19-11-2007, 14:31
FTtyler's Avatar
Thanks For the help guys.
Does anyone else have some more ideas?
  #102   Spotlight this post!
Unread 10-12-2007, 21:42
grantman54's Avatar
grantman54 grantman54 is offline
None #1388
grantman54 is an unknown quantity at this point
Hey my team is very interested in NBD. Last year we used the Andy Mark 2 speeds trannys for the drive train. They just didn't seem to be worth the weight and cost. My questions are:
  • How reliable is "shifting on the fly"? Anyone have major failures?
  • Is it unreliable because of servos not acting at the same time or just the characteristics of the NBD?
  • IF it is the servos, would replacing them with pneumatics fix this? Seems to me like it would. anyone tried?
  • Would using two CIMs to one Dewalt transmission be too much for the Dewalt? Is an extra CIM even worth it? (drivetrain)
(Pics are always helpful )
Thanx,
Grant
  #103   Spotlight this post!
Unread 10-12-2007, 23:35
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
To answer above, it was fairly reliable last year, with no major failures. The unreliable part was piano wire was very hard to work with and we ended up using a ball link. We decided not to shift to all 3, just using 2, as the servo did not have enough power alone. Pneumatics can be used, just may be harder to integrate. We used the extra CIM, and our friends, 1070, did not.
They had an effective time I think with the NBD setup, and so did we. Definitely hard to create an adapter mid-season without instructions to fit 2 CIMs into the NBD, but the BaneBot 2 CIM adapter helped. Mounting also was a difficulte problem to solve mid-season. Planning ahead can help reduce the stress if you guys go with 2CIMs into one DeWalt.
I have a question....
The newer model DC940 is now out, and its hard to find the model that the NBD was made for (DC980KA). Does anyone have the specs or a CAD of the new DeWalt drill tranny?
My other car is being built to go to Mars in 2011.
Bet you aint got one of these...
  #104   Spotlight this post!
Unread 02-01-2008, 04:07
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Does anyone know of a place to find the DC980KA anymore?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
  #105   Spotlight this post!
Unread 02-01-2008, 08:00
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Richard,
If you're just looking for parts for a NDB transmission, go here: http://www.dewaltservicenet.com/
