Go to Post The 3 probably stands for the number of years this season will take off your life - JohnSchneider [more]
Unread 03-11-2007, 16:42
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Re: pic: Planetary Transmition
Thank you very much for all the comments. The reason that I'm using the banebots is because it comes with many of the necessary gears. I'm developing the concept because it is very easy to change the change in reduction by changing the size of the second planetary sun gear. At the moment with a 22 tooth second gear the ratio changes from 1:30 to 1.1:1. If instead I used the gears from the second stage of the banebots (sun being 30 teeth), the reductions would be 2.25:1 and 1:9 which is a much smaller difference in reduction.
Basically this can have a large number on different combinations of reductions without a change in the form factor. Also if anybody wants to check me on those reductions (would definitely be wise) I think that it would actually work better to have the larger gear on the first stage of the planetary. At the moment I believe the directions of the output would depend on the gear your in. So when you changed gears the robot would change direction...
Thanks again for all the coments
pic: Planetary wheel (cutaway) FourPenguins Extra Discussion 6 01-01-2007 14:56
pic: Planetary...Wheel? Matt Krass Extra Discussion 23 27-06-2005 16:05
pic: Planetary Wheel - Exploded View 4 Matt Krass Extra Discussion 5 23-06-2005 23:56
pic: Planetary Gearset CD47-Bot Robot Showcase 3 22-12-2003 01:55
pic: Drill transmition CD47-Bot Extra Discussion 19 28-10-2003 09:23
