Go to Post I'm so conflicted right now. On one hand, you made the same page as a celebrity. On the other hand.... Justin Bieber. - Akash Rastogi [more]
Unread 10-11-2007, 19:56
Anne Shade Anne Shade is offline
Maryland Regional Director
AKA: Formely Anne Bergeron
no team (FIRST Chesapeake)
Anne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond repute
Send a message via AIM to Anne Shade
paper: Electrical Tips Handout
Electrical Tips Handout by Anne Bergeron
Unread 10-11-2007, 23:51
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Re: paper: Electrical Tips Handout
I would add
Secure all wires - Make sure to secure all wires so they don't wander around the robot. Loose wires will tend to make screws come loose, and the darn PWM cables will always end up in the wrong place at the wrong time (durint a match) and cause a great amount of Magic Smoke. Also, loose wire will give an opportunity for another robot's parts to become entangled within the veins of your robot and rip them out, causing your robot to die.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 12-11-2007, 22:19
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
Use solid wire on the main wiring board, you can make perfect bends so it will look pretty. Us electricans will make the students do it over and over until it looks good.For other electrical tips http://team1322.org/electrical.htm
Unread 12-11-2007, 22:54
alex1699's Avatar
alex1699 alex1699 is offline
ummmm thats meee......
FRC #1699 (robocats)
alex1699 has a spectacular aura aboutalex1699 has a spectacular aura aboutalex1699 has a spectacular aura about
Send a message via AIM to alex1699
that is amazing pretty
Curie..
Unread 13-11-2007, 13:08
in between teams
AKA: Luke Van Oort
I disagree, as I understand it (granted, I'm no electrician), stranded wire is a better choice in areas that experience a lot of vibration, such as a FIRST robot. Plus, sharp bends increase the resistance of the wire.
Team 1219: 2009 - Mentor
Unread 13-11-2007, 15:11
joeweber's Avatar
Coach team 1322
The location for the solid wires is from the fuse block to the vic884 and spikes. From their on you would have to use stranded. I suppose you could use solid up to the quick connectors at the motor leads. Tie wraps will hold down the wire for the vibrations, of course you would have to use stranded for the moving joints and protect the wire.
I am sure many of you have seen some wiring practices that look like spaghetti. I try to instill some pride in our students when they wire the robot. Think about how you are going to run the wires before you install them. If they make it look sloppy I will make them do it over. The older students watch the new students when they wire and automatically make them do it right. If you are wiring a machine in the factory you don’t dare make it look bad, the other professionals will be all over you in a second and they will not let you for get it. Do it right , make it look good, and always use the right size wire.
Unread 13-11-2007, 15:17
joeweber's Avatar
Coach team 1322
I forgot to mention the sharp bends, you can watch the bends, but for the distance we are runing 3 to 20 inches the amount of resistance on a 20 amp and 40 amp circuit is not even worth woring about. If you are use the next size wire.
Unread 13-11-2007, 15:51
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
as simple as it may sound, out team has made this mistake before:
POSITIVE +NEGATIVE = BAD!!!
Unread 13-11-2007, 16:02
GVDrummer's Avatar
GVDrummer GVDrummer is offline
AKA: Jake Hall
FRC #0216 (RoboDawgs OTL)
GVDrummer is on a distinguished road
Send a message via AIM to GVDrummer
Don't forget to mention that every connection must be covered eathier by wire nuts or along the lines of electrical tape. Not live connection should be open. Even connections to fuse boxes, motors, sensors, ect.
Unread 13-11-2007, 16:18
joeweber's Avatar
Coach team 1322
Yes that can be a problem, in our feild (electrical wiring) the black is hot and white is ground. In the robot black is ground and white is positive. One year I was not watching and all the wires were revearsed, I caught this before it was too late. We quickly rewired.
Something else we do is make a small wire way that can be mounted 2 inches above the wiring board. In this we route the control wires. This way they are separt
paper: FIRST Publicity Tips Mark McLeod Extra Discussion 0 19-05-2006 10:01
White Paper Discuss: Competition tips/What to expect Anne Shade Extra Discussion 2 16-12-2004 16:36
White Paper Discuss: Team organization tips Anne Shade Extra Discussion 0 13-12-2004 10:01
Electrical Tips for Rookies Anne Shade Technical Discussion 15 03-12-2004 12:08
White Paper Discuss: Team Regional Perfomance at your finger tips... CD47-Bot Extra Discussion 4 14-04-2004 13:56
