Go to Post They can either incorporate the suggestions in this thread, go totally against them, or even make us all write code on banana peels with our fingernails. - Andy Baker [more]
Unread 25-11-2007, 10:42
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: pic: Kitbot Chain Tensioner 2
Originally Posted by Doug G View Post
We tried an approach like that in 2006, but yours is very elegant. In 2007 we gave up with it and used a super simple solution... A chuck of UHMW PolyEthylene Rod with a hole drilled in it offcenter. Rotate it into the chain and whala... Tension!! Rotate it the other way and you can remove chain off the wheel. Very simple and worked well. True there is a bit more frictional loss - but in 7 years of competing, we never had a simpler, more reliable solution. .Here's a pic..
Just out of curiosity, where did you get those gears for the encoder setup you have? And how is the lower gear on the 1/2" Banebots shaft attached? Is it a set screw? Did it come with that 1/2" bore or did you have to enlarge it?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: Kitbot Chain Tensioner 1 Donut Extra Discussion 6 21-12-2006 00:43
Chain tensioner usage Rhs953 Kit & Additional Hardware 3 10-02-2004 17:04
Chain Tensioner? Gabriel Technical Discussion 14 29-01-2004 09:16
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
