Go to Post Dave doesn't predict the future. He creates it. - Alan Anderson [more]
Unread 25-11-2007, 16:37
patrickbosch patrickbosch is offline
FRC #1351
patrickbosch is an unknown quantity at this point
Re: pic: Kitbot Chain Tensioner 2
Originally Posted by Doug G View Post
We tried an approach like that in 2006, but yours is very elegant. In 2007 we gave up with it and used a super simple solution... A chuck of UHMW PolyEthylene Rod with a hole drilled in it offcenter. Rotate it into the chain and whala... Tension!! Rotate it the other way and you can remove chain off the wheel. Very simple and worked well. True there is a bit more frictional loss - but in 7 years of competing, we never had a simpler, more reliable solution. .Here's a pic..
Ha, we had this idea as well, except it was cammed delrin for a tensioner. It appears as if it worked very well, did you have any problems keeping the tensioner from slipping?
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: Kitbot Chain Tensioner 1 Donut Extra Discussion 6 21-12-2006 00:43
Chain tensioner usage Rhs953 Kit & Additional Hardware 3 10-02-2004 17:04
Chain Tensioner? Gabriel Technical Discussion 14 29-01-2004 09:16
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
