Go to Post studies have shown that postive feedback works better. Driver should get a shock until he obtains target lock, then it stops. Performance incentive :^) - KenWittlief [more]
Unread 26-11-2007, 14:50
JesseK JesseK is online now
Re: pic: Team Unlimited's Gear Shifter
Since it's not single-design oriented, I believe I can answer the motors per side question.
Certain teams might not find it necessary to have 2 drive motors per side. However when you weigh the entire robot down with steel manipulator parts, if you're geared for speed you'll definitely notice lackluster power due to the extra mass. In other words it will take (seemingly) forever for the bot to get up to speed.
If you have a very lightweight bot or it's only geared for med-high torque situations (therefore low speed) you could probably get away with 1 motor per side.
GitHub
pic: FVC 2013 Gear shifter gdo Extra Discussion 16 27-04-2007 14:25
pic: 1732's 2 servo shifter John Wanninger Extra Discussion 1 04-03-2007 23:27
pic: Team 948 2 speed dog shifter adlai Extra Discussion 3 05-12-2006 07:54
pic: team 1029 shifter bjimster1 Robot Showcase 4 21-02-2006 10:23
pic: AM shifter mount close up falconmaster Extra Discussion 2 18-01-2006 19:27
