Go to Post Trapping JVN (or any other IFI employee) is negative infinity [I]and[/I] a caption contest. Trapping 1114 is a measly 50 points, unless you trap Karthik, which multiplies your entire score by -1. - EricH [more]
Unread 29-11-2007, 23:45
yongkimleng yongkimleng is offline
deus ex programmeur
AKA: James Yong
FTC #0747
yongkimleng is a jewel in the roughyongkimleng is a jewel in the roughyongkimleng is a jewel in the rough
Send a message via MSN to yongkimleng
Re: pic: Back-in-Black 4-speed Top View
There is an excel associated with the whitepaper which tells you the rpm's to shift at based on motor input and ratios. Not sure where to get it anymore besides contacting team 33. Once you have those shift points it is a little bit of a challenge. We haven't done it yet, but we think a big case statement where each gear is a case. In each gear, it compares the current rpm to the shift points to determine whether to stay in gear, or shift up/down.
Hmm since we have 4 ranges, for each of the possible gear combinations, I think a binary nested if-else block suffices and should run fast enough
very interesting setup there.. next best thing to variable belt drives
| jamesyong.net |
FVC2007, FTC2008
OTTO '07 - Back in Black rfolea Robot Showcase 1 23-02-2007 21:03
pic: A View From the Top CMB Extra Discussion 2 10-01-2007 22:21
pic: Lego Kiwi Bot Top View Michael Corsetto Extra Discussion 2 02-01-2007 10:46
pic: Top View of Shaft Drive MAteo9944 Extra Discussion 2 30-12-2006 20:59
pic: Team #910 Top View CD47-Bot Extra Discussion 7 06-03-2003 12:41
