Go to Post I just got pwned by Dave...how awesome is that?! - Tetraman [more]
Unread 12-12-2007, 14:03
Re: pic: Concept Frame
I would reccomend attaching the two parallel rails on each side directly to each other. If you attach them in two places, between the center wheel and each outer wheel, it won't interfere with your plan for ramp climbing.
Also, if you plan on using this frame next year, and the game is rampless, I would connect the two rails in the front and back as well.
Looks like a good start though.
Unread 12-12-2007, 14:14
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
The two long bars that run on the inside of the frame, I would make them the same length as the outside bars that run parallel to them. That way, if there is a situation where you need to open up one end of the robot for ball collection or placing an arm, then you can accomplish this by simply sliding the front bars backwards.
Unread 12-12-2007, 14:27
MrForbes MrForbes is online now
I would start by drawing all the parts that connect to the frame, then fill in the gaps with the frame
Unread 12-12-2007, 14:32
EricH EricH is offline
Looks almost like the one 330 did for the 2006 season...we moved the end rails farther in. For 2005 and 2007, we had three rails for mounting purposes on the inside.
Some pros and cons of the design:
Pros:
--clearly defined "keep out" zone due to the double rail
--strong
--simple
Cons:
--weight (those top bars add a lot--if you can remove them, do so.)
--Welding is virtually required.
--As drawn, the frame could bend if it takes a side hit. Consider adding inner blocks where the wheels won't go. (Which will also render the top bar mostly unnecessary.)
Unread 13-12-2007, 15:03
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
I would add a thin walled crossbar from the left front to the right rear, this could add some cross support, while also adding a light way to support a sheet of lexan to hold the electronics. This can also be done with a flat piece of aluminum.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 16-12-2007, 20:55
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
hmm... did you draw that in google sketchup by any chance?
-vivek
pic: Unique drive concept Joe G. Extra Discussion 36 12-05-2007 20:27
pic: 114 wheel concept CraigHickman Technical Discussion 8 22-06-2006 14:24
pic: Concept Gearbox Bill_Hancoc Extra Discussion 12 17-11-2005 20:54
pic: Claw^2 Concept CD47-Bot Extra Discussion 8 06-02-2004 14:08
pic: Crab Concept 6 CD47-Bot Extra Discussion 13 14-11-2003 22:03
