Go to Post It's wrong to scuttle someone else's boat because you don't think it's seaworthy. You probably don't know that what you were seeing will be called a submarine. - ThatHat [more]
Thread Tools Rating: Thread Rating: 25 votes, 4.84 average. Display Modes
  #226   Spotlight this post!
Unread 16-12-2007, 15:59
DonRotolo's Avatar
Back to humble
FRC #0832
Re: pic: Game hint
Originally Posted by hipsterjr View Post
This is defiantly legit
defiantly indeed. Freudian slip?
Originally Posted by neutrino15 View Post
I am guessing that there will be stations around the field that give data to the robot.. And the robot has to carry that data to another station..
Perhaps, but how to "send' that data once it gets there?
Originally Posted by billbo911 View Post
My guess is they will not be using a 38KHz transmitter to limit the amount of reflected and false signals on the field.
38 kHz is a standard modulating frequency for IR remotes, used by almost all manufacturers. The IR receive module from Radio Shack is centered on 38 kHz as well.
The idea is to filter out the 38 kHz Carrier (that is, demodulate the data) to dramatically increase the resistance to noise and stray IR. Any such circuit will have low sensitivity to carrier frequencies other than 38 kHz. Cable TV remotes generally do NOT use 38 kHz to avoid interfering with (or controlling) the TV/VCR/DVD/etc to which they are attached.
Originally Posted by robotcanuck1676 View Post
THIS IS MAKING ME GO CRAZY!!!
This assumes that sanity was the starting point... Alas, and sadly, this is not so...
What we know:
1. Not a hoax
2. Used for FRC 2008
3. Can be used to receive/decode up to 4 IR signals, and act upon them.
4. Compatible with systems on the Robot.
5. The team can pick (teach) the four IR signals...
6. It works from at least a few feet away.
Speculating, if it's on the 'bot, and the 4 signals are unique* to a team, then only that team** can do something with it - sounds like a remote version of the autonomous "version" switches many teams use.
Teams will need to change autonomous*** strategies after the field is set and teams are at the player stations, but before the match begins. This board allows that.
Don
* They get to pick the remote & buttons used for teaching, right?
** Hypothetically, two teams could pick the same remote AND the same buttons...but that's unlikely, and can be mnodified at competition anyway.
*** Or maybe change something fundamental during regular play, but I suppose the OI can be used for that...
  #227   Spotlight this post!
Unread 16-12-2007, 16:11
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
Re: pic: Game hint
Changing your autonomous mode from the players' station - doesn't that come really close to defeating the purpose of the autonomy of it? If you need to change your autonomous at the last minute, a binary switch on the RC can do that very easily...
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
  #228   Spotlight this post!
Unread 16-12-2007, 16:15
dr1008's Avatar
dr1008 dr1008 is offline
AKA: Zack Rhodes
FRC #1008 (Team Lugnut)
dr1008 will become famous soon enough
Re: pic: Game hint
i agree, it seems like way too much hassle for you to do something that 1 you should already have planned before the match and 2 it would be easier to just have a manual switch on the robot that you can change while setting it up for that match, there is almost no time anyways from when you set it up till when the match begins, so theres not much time or need to change your mind.
1008 in 2008 this is our year!
<a href="http://www.thebluealliance.net/tbatv/team.php?team=1008" style="border: 0"><img src="http://www.thebluealliance.net/tbatv/teambadge/gen/1008/0000FF/FFFFFF/teambadge.png" alt="Team 1008" /></a>
  #229   Spotlight this post!
Unread 16-12-2007, 16:18
Cooley744's Avatar
Cooley744 Cooley744 is offline
Cooley744
AKA: Lauren
FRC #0744 (Shark Attack)
Cooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to behold
Send a message via AIM to Cooley744
Re: pic: Game hint
Wow. I'm really confused and my brain hurts. Watch this really be a hoax. lol that would be great.
For whatever you do, work at it with all your heart, as working for the Lord, not for men.
Colossians 3:23
Proud graduate and now lead strategy mentor and driving coach for 744 Shark Attack.
  #230   Spotlight this post!
Unread 16-12-2007, 16:22
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
Re: pic: Game hint
I agree. Seems like a lot of effort for so little purpose... Also, commenting on people's ideas of "robots going from station to station to get data to score points": would that not be the most boring game you've ever seen. Seriously, if that was the game, I'd cry. I can just see it now... everyone sitting in the stands and an announcer trying to sound enthusiastic about a robot getting data...
That's about as exciting as making a sandwich... or maybe thinking about making a sandwich...
  #231   Spotlight this post!
Unread 16-12-2007, 16:25
StephLee's Avatar
AKA: Stephanie
Re: pic: Game hint
Probably thinking about it; seeing a robot trying to handle mayo might be at least a little funny, if not exciting...
  #232   Spotlight this post!
Unread 16-12-2007, 16:27
AndyB's Avatar
AKA: Andy Burchardt
Re: pic: Game hint
Haha, Subway is now a FIRST sponsor...
  #233   Spotlight this post!
Unread 16-12-2007, 16:29
Billfred's Avatar
Billfred Billfred is offline
Re: pic: Game hint
I agree. Seems like a lot of effort for so little purpose... Also, commenting on people's ideas of "robots going from station to station to get data" would that not be the most boring game you've ever seen. Seriously, if that was the game, I'd cry. I can just see it now... everyone sitting in the stands and an announcer trying to sound enthusiastic about a robot getting data...
Getting data would be a lousy game (though it would also be grounds for a nice fifty-motor drive, since you probably wouldn't need much in the way of an arm). But let's suppose there was a specialized field element robots had to negotiate to receive some information that is relevant to their interests. A box or area that robots had to stick the sensor into could make for an interesting test, particularly if that information can make the difference between a Good Robot and a Great Robot.
  #234   Spotlight this post!
Unread 16-12-2007, 16:32
AndyB's Avatar
AKA: Andy Burchardt
Re: pic: Game hint
I like the idea someone else came up with of using the infared soccer ball that was posted earlier.
A game piece involving infared would be more interesting... I don't know why you would need an infared sensor to use it though... unless you wanted to get to this game piece during autonomous mode...
Thinking about it, the real question we need to be asking is: why the need to go infared when we already have the CMUcam...
  #235   Spotlight this post!
Unread 16-12-2007, 16:34
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Re: pic: Game hint
YEAH!! Look at those 0's and 1's just fly into team xxxx's IR chip!! Yes ladies and gentlemen, they are moving at the speed of light! Aww, it looks like they got knocked over....
At least the game pieces wouldn't get stuck on the freaking flag
-vivek
p.s. It might be cool if the game pieces were identical in everyway except that they put out different IR signals. two goals: wrong IR game piece gets one point, correct IR game piece gets two points? eh... I need to do my homework.
  #236   Spotlight this post!
Unread 16-12-2007, 16:36
AndyB's Avatar
AKA: Andy Burchardt
Re: pic: Game hint
-vivek
Hahaha, that is an advantage to a pretend game piece...
  #237   Spotlight this post!
Unread 16-12-2007, 16:41
DonRotolo's Avatar
Back to humble
FRC #0832
Re: pic: Game hint
No, not a water game, or a Jello game....but a MAYO Game!!
(Ewww).
  #238   Spotlight this post!
Unread 16-12-2007, 16:45
njamietech's Avatar
njamietech njamietech is offline
AXE 'EM JACKS
AKA: Neal Jamieson
FRC #0624 (CRyptonite)
njamietech is a glorious beacon of lightnjamietech is a glorious beacon of lightnjamietech is a glorious beacon of lightnjamietech is a glorious beacon of lightnjamietech is a glorious beacon of light
Send a message via MSN to njamietech
Re: pic: Game hint
honestly, I can't get a clear idea of what this is used for.
but I wonder if they are leaving out an item left in the kit. Such as a transmitter perhaps?
Perhaps we will be able to interact with other robots without harming them. (like lazer tag).
One thing I have noticed is that we are forgetting that FIRST may have left other parts relating to this device in the kit and secret.
We should probably take into account the possibility of items kept secret.
  #239   Spotlight this post!
WillItBlend's Avatar
WillItBlend WillItBlend is offline
Ctrl+Alt+De1337
AKA: German Khmelnitsky
FRC #0334 (Tech Engineers)
WillItBlend will become famous soon enoughWillItBlend will become famous soon enough
Send a message via AIM to WillItBlend
Re: pic: Game hint
Originally Posted by fimmel View Post
well the pdf was created friday december 14th 2007 at 3:39:46 pm by adobe distiller....nothing spectacular...the author though is kpilotte after a quick google search it turns out theres a photobucket account with that username http://smg.photobucket.com/albums/v641/kpilotte/ and a stumbleupn account http://kpilotte.stumbleupon.com/ an ilounge account http://forums.ilounge.com/showthread.php?t=57728 and something promising is she had an @usfirst.org email address... http://www.sensorsmag.com/sensors/Se.../detail/314079 under more sensors please. from what i gather she is part of FIRST's sensor development team.
kinda crazy lol
may be useful idk
if you notice, it says shes from from virginia on stumble upon, and maryland on ilounge. but nice job sherlock.
  #240   Spotlight this post!
Unread 16-12-2007, 16:48
AndyB's Avatar
AKA: Andy Burchardt
Re: pic: Game hint
I'll say it again... this IS the game piece... get your circuit board harvesters ready!
pic: 2007 Game Hint? dlavery FRC Game Design 161 07-01-2007 13:42
pic: 2007 Game Piece Hint Wetzel Extra Discussion 39 07-01-2007 00:24
Offical Game Hint! Greg Needel Rumor Mill 117 21-12-2006 16:25
dlavery game hint nuggetsyl Rumor Mill 173 20-12-2006 22:00
Game hint?!?! Andy Grady Rumor Mill 67 30-12-2002 18:15
