Go to Post This isn't a science fair, sometimes it's okay to give away the answer, especially if they learned something on the way there. - Karthik [more]
Unread 18-12-2007, 01:59
Billfred's Avatar
Billfred Billfred is offline
Re: What is the best place to mount CIM motors...?
The answer is: It depends. If you do live axles, you can drive the center wheel (which won't spin any faster than the other two; they'll all turn at the same speed). With dead axles, the gearboxes have to go elsewhere. Where you put them depends on your weight distribution; we put them on the front when the heavier part of the robot was in the back, and a problem with our wheel screws on the center wheel bit us in the butt. Hard.
Ideally, you'll make sure your drive system can handle some Irritating Failures without them becoming Paralyzing Failures.
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Where to get the CIM motors? PlasmicDragon Motors 5 22-01-2007 14:03
2 CIM motor mount 56 mm banebox... brennerator Inventor 2 19-01-2007 07:57
Large CIM Motors - Removing the sprocket PuiChi Motors 5 13-01-2006 16:01
Do the CIM motors emit a magnetic field? JulieB Motors 17 27-01-2005 12:59
