Go to Post One of my management professors taught me this: At all times you are holding a bucket in each hand, one full of water, and one full of gasoline. Management is knowing when to throw which bucket. - Barry Bonzack [more]
Unread 18-12-2007, 04:41
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: pic: Crab Drive Frame
Originally Posted by yongkimleng View Post
Hmm is it a good idea to have 2 gearboxes driving the wheel orientation? Maybe they move at different speeds / distance moved and cause uneven tension on the chains across the two sides..
He has a "tank crab" set up right now.
EDIT: How do you plan on controlling this. Are you going to use the "tank crab" where you will have two joysticks or one joystick with some really sick programming? The picture is kind of misleading me. If you decide to link one side of your robot to the other via chain than you will save weight if you don't want to do akerman steering. Anyways let me rephrase my question, what exactly will your crab, when it is all said and done, be able to do?
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
pic: Ultimate Vex crab drive 2 cire Extra Discussion 9 01-06-2007 16:46
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
pic: Tredded-Tripedal-Modular-Crab-Drive CD47-Bot Robot Showcase 11 28-04-2004 22:06
pic: Coaxial Lego Crab drive CD47-Bot Robot Showcase 11 04-11-2003 14:45
