Re: pic: 2008 IR Board Model
Oooh.. Molex eh?
![]() I'll have to ask a few of the guys at work who worked there or worked with them through their professional careers about this discovery. (I work at a place where we make cable assemblies, connectors, and antennas. We have a lot of good people from the cable & connector industry workin' with us.) Thanks for the info! |
2) I encourage you to pull up the data sheet online and confirm. 3) KK Friction Locks are used EVERYWHERE. I don't mean to be a wet blanket, but I will be very impressed if that piece of information leads to anything. It tells you about as much as knowing what model of PIC is on the board. |
Oh wells. No harm in trying to decipher just another detail of the board I guess. ![]() |
Bingo! http://delta.octopart.com/Molex__22-23-2061.pdf
This seems to match. Quote:
But, now comes the big question. What's the mystery cable going to that this component is going to be used for? Typically these type of connectors (from what I can gather) are used for power supplies on computers. Possibly we can adapt these with the Ribbon cable provided via a crimping type mate housing: http://www.molex.com/catalog/pdf/MX2695.pdf With this baby on the end of the wires: http://www.molex.com/pdm_docs/sd/008650804_sd.pdf Can't be that hard to do. ![]() Last edited by Elgin Clock : 19-12-2007 at 13:38. |
looks like you nailed what it is!! now what can it be used for is the question of the hour isn't it?
If only I knew.....I'd be able to share it with you all... too bad I don't know Any guesses??? I'm not electrical guy so I'm not so sure about it at all |
Saaaaaaaayyyy....
Isn't that the connector used on the F.L.U.X. Capacitor? ![]() |
The patent on that expired just 2 months ago. Man these guys work fast ![]() |
does anyone know what this has been used for in the past?
#11
This is the first year we've had this.
#12
if you had a guess what do you think this IR Board Module could be used for?
#13
http://www.tfaw.com/Profile/Back-To-...plica___311677 |
| 2008 Offseason event MARC being moved to JUNE 28, 2008 | Steve Ketron | Off-Season Events | 10 | 21-03-2008 07:55 |
| Model Airplane Propeller Model | SgtMillhouse648 | Inventor | 2 | 20-08-2007 19:08 |
| Lights in Joystick board or control board | rcubes85 | Control System | 15 | 26-02-2005 23:40 |
| pic: Field Model | Pâzinha | Extra Discussion | 3 | 23-01-2005 08:56 |
| Perf Board = BS2-IC Carrier Board? | indieFan | Electrical | 2 | 16-09-2004 08:28 |
