#496
Re: Recieve ours
Same thing I said when I saw it. It's smaller than the CMU camera board, by about half.
#497
Re: pic: Game hint
As i just finished reading through all the other posts I have a question for Dean Kamen, Dave Lavery, or our new sponsor diversified Systems (or any other official FIRST people): since it IS the season for gifts are there any other nice little hints you would like to give to the good little boys and girls who spend so much time theorizing and reading this thread? If there is a place with divsys's CAD file for the board I could use a link. Thanks and happy holidays!
#498
Re: pic: Game hint
For the chip is FIRST sending out backups to teams or just one?
#499
Re: pic: Game hint
Thank you so very much for the generous donation. I humbly apologize for even thinking that DEC was involved (tells you where my head is at: I did not even realize it was December!) and failing to recognize your company's involvement. A big thanks to Vishay as well! It must be so cool to work at (own?) a place where they have pick-n-place machines AND wave soldering equipment. Kind of like my idea of an amusement park, or maybe a shopping mall.... -...- Anyway, Team 1676 got their little envelope today, and I think everyone needs to be reminded: This board is NOT large. It's about the size of the sensor board in the KOP last year, maybe 1.5" x 2.5"? The little square of paper with the web address on it is smaller than a business card. Think Small. All the more reason the believe it'll be mounted to the robot. So, repeating what 09randy (oh, ydnar90) wrote: Hey, how 'bout a poem to go with this hint? Don |
#500
Maybe since every team is going to program this circuit with their own remote, perhaps the PIC contains enough RAM to download the settings to the camera for detecting different colors of goal lights.
It would be up to the driver team to bring their robot close enough to the driver station to control the PIC with the team's remote to detect the ever-changing goal light. |
#501
Re: pic: Game hint
I would say just 1 per team because they are donated by Vishay and it may be a loss to the company. However, you could ask him or www.divsys.com to be sure.
#502
Re: pic: Game hint
Tried out ours tonight, but it doesn't appear to be working as expected.
It seems to learn about four different remotes (found one it didn't acknowledge at all and another it objected to via the error LED), but after going through the learning sequence it won't respond to any of them in any way. BTW One of the traces from the unmarked white connector appears to go to the learn button. Last edited by Mark McLeod : 18-12-2007 at 23:17. |
#503
Re: pic: Game hint
3 days early what? was an 'official clue' supposed to come out today? |
#504
Re: pic: Game hint
Re: pic: Game hint
It was supposed to be delivered today, apparently. Joe got it Saturday.
#506
Re: pic: Game hint
Once we all see the game, I think this little puzzle will all make perfect sense. |
#507
Re: pic: Game hint
This has been an impressive thread with all the speculation as to how this IR board will be used. Here is my two cents. Think about what FIRST has always done...they want the teams to develop solutions to problems. NASA eventually wants to put up bases on the Moon & Mars. You need robots working together to make that happen. I bet that the KOP will contain an IR transmitter that will mount on the robot along with this receiver. Robots on the field are going to have to work together to accomplish a task such as a coordinated lift. Four outputs - UP, DOWN, FORWARD, BACK come to mind. The instructions for setting up with a TV remote are so you can test the bot before competition. The white plug would be for regional programming when you bring the robot up for inspection so everyone has the same "learned" program. The LED's on the board would be for diagnostics when checking the bot out during the build and confirming the programming at the regionals. Most likely wrong, but its a thought.
#508
Re: pic: Game hint
Umm.... I'm not exactly sure which wires do what. which leads do you have to strip back and apply power?
From the manual I think it's "saying" Brown and Red are + Posotive, and Orange, Yellow are - Negative Bonus question: Does anyone have any ideas as to hook this up to our robot as a sensor for "pre-testing"? TTL port? or just apply power, and then wire 5 - 8 to spare PWM cables. To the white wires? Last edited by keen101 : 19-12-2007 at 04:43. |
#509
Re: pic: Game hint
Never mind. I couldn't resist.
OK, so I found an old 2pin sensor (female) cable end, and connected it to the two lower right hand pins. The one labeled "2"(RED?), and the one nest to it which I am assuming is 4 (Yellow?) Anyway it worked. I was able to program code 1 with a button on my cheap DVD remote. As for the Sensor part.... I will assume you connect them to old PWM cables. However I could be wrong, so I'll wait to hear otherwise. |
#510
Re: pic: Game hint
With the speculation about RoboLaser Tag, could the response be to shut down for a period after receiving a signal? Is your sensor still unresponsive? Have any other teams found results they are willing to share? |
| pic: 2007 Game Hint? | dlavery | FRC Game Design | 161 | 07-01-2007 13:42 |
| pic: 2007 Game Piece Hint | Wetzel | Extra Discussion | 39 | 07-01-2007 00:24 |
| Offical Game Hint! | Greg Needel | Rumor Mill | 117 | 21-12-2006 16:25 |
| dlavery game hint | nuggetsyl | Rumor Mill | 173 | 20-12-2006 22:00 |
| Game hint?!?! | Andy Grady | Rumor Mill | 67 | 30-12-2002 18:15 |
