Go to Post Thankfully, no magic smoke was released during the making of these photos. - SteveGarward [more]
Thread Tools Rating: Thread Rating: 25 votes, 4.84 average. Display Modes
  #511   Spotlight this post!
Unread 19-12-2007, 08:20
Bill Moore's Avatar
Bill Moore Bill Moore is offline
Iv2gr8sons
AKA: Be More
FRC #0365 (Miracle Workerz)
Team Role: Team Spirit / Cheering
Bill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond repute
Send a message via AIM to Bill Moore
Re: pic: Game hint
Originally Posted by Turtlecoach View Post
This has been an impressive thread with all the speculation as to how this IR board will be used. Here is my two cents. Think about what FIRST has always done...they want the teams to develop solutions to problems. NASA eventually wants to put up bases on the Moon & Mars. You need robots working together to make that happen. I bet that the KOP will contain an IR transmitter that will mount on the robot along with this receiver. Robots on the field are going to have to work together to accomplish a task such as a coordinated lift. Four outputs - UP, DOWN, FORWARD, BACK come to mind. The instructions for setting up with a TV remote are so you can test the bot before competition. The white plug would be for regional programming when you bring the robot up for inspection so everyone has the same "learned" program. The LED's on the board would be for diagnostics when checking the bot out during the build and confirming the programming at the regionals. Most likely wrong, but its a thought.
Earlier this fall, as FIRST was releasing information, I was surprised at the number of times they addressed "collaboration". Taking your NASA idea to a more present engineering achievement, consider the International Space Station. This is an Engineering task that must be coordinated between teams of engineers very distant from each other, yet the separate components must match up in space, or their efforts will be wasted.
BIG WHAT IF . . .
What if FIRST provided a docking ring and collar system in the KOP, and teams had to build both a drive system and an actuator assembly that could be separated by using this docking system.
Then at competitions, teams would not only play together, but would have to use the drive from one team with the actuator from another. You could have 2 robots vs 2 robots matches and increase each alliance to 4 teams (8 teams per match). Teams would only play with half their robot, and they could mix and match among the alliance to get the best fit of robots.
It would be very difficult, but by encouraging collaboration, it would mimic a current engineering task.
Three Signs You Are Getting Old: 1) You forget things, 2) You begin repeating yourself, 3) You forget things.
  #512   Spotlight this post!
Unread 19-12-2007, 09:16
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Re: pic: Game hint
BIG WHAT IF . . .
I dont think that first will like the idea of some teams using other teams drive systems/operational systems.
It might just take the whole game out of the driver-skills.
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
  #513   Spotlight this post!
Unread 19-12-2007, 12:00
Turtlecoach Turtlecoach is offline
2007 NASA/VCU Champions
FRC #2108 (Awkward Turtles)
Turtlecoach has a spectacular aura aboutTurtlecoach has a spectacular aura aboutTurtlecoach has a spectacular aura about
Re: pic: Game hint
I'm thinking more along the lines of one bot synching operations with another. Here is the scenerio - Two aliance bots approach object to move together, 1st bot would be in Master mode, 2nd bot would be in Slave mode. Both bots go to pick up / move object and Master bot sends a sync signal to Slave bot via IR so both lift mechanisms operate simultaneously. This way you can get coordinated lifts, provided of course that the lift mechanisms operate at the same rate. In a similar manner both bots could be synched to move at the same time or operate two seperate field targets at the same instant to open gates, doors, etc... This would be slick and make the collaboration hints valid. Remember what FIRST was trying to teach in 2007. What will your opponent / alliance member build and how can you accomodate / defend against it.
  #514   Spotlight this post!
Unread 19-12-2007, 12:05
Onward through the fog.
Re: pic: Game hint
Looking at it a little differently, cup 1/2 full - it could present different challenges and opportunities to the drive teams and to the build. The excitement of the '07 game was the collaborations of the robots and of the drive teams working together.
~ Helen Keller
(1880-1968)
  #515   Spotlight this post!
Unread 19-12-2007, 12:28
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
Re: pic: Game hint
i am not impressed.!
you have all missed the most obvious clues with this board. you keep trying to fasten it to the robot.
clues
1. the power available from a robot controller is +7.2 and +5 volts.
the power for a field component is usually a 12 volt battery.
this board runs on 5 volts but requires between 7 and 15 volts!!
2. the ribbion cable is not configured anywhere like a digital connection on the controller.
3. the learning of a remote allows the newton field to use differrent codes from the curie field.
if each team had to learn an alliance partner code it would take too much time between matches.
4. there are 4 outputs from the board. there are 4 corners on the field. 2 red remotes and 2 blue remotes would allow teams to trigger 4 release mecanisms.
we have cmu-cam to collect data. now we will have IR remotes on the robot to send data to the field.!!
please put this board on the field where it belongs.
jerry w
Happiest when people tell the truth... However, I am blessed with many friends.
  #516   Spotlight this post!
Unread 19-12-2007, 12:48
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: pic: Game hint
Originally Posted by whytheheckme View Post
OOOH!!!!
Maybe my dream of a more field oriented positioning system is coming true!!!
Maybe, on the field, there are IR emitters all over the place, each giving off a different code. You can use the IR receiver to pick up these codes, and tell where your robot is.
YES
Jacob
This is actually very possible IMO. I am actually planning on creating this type of thing, similar to STANGPS except different technology different sensors etc and cheaper and possibly redistributing it as a white paper. Hopefully FIRST is doing this for us but I believe that if real development in this "Field Mapping" type project is to occur than it will be team led since FIRST wants US to develop that type of stuff.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
  #517   Spotlight this post!
Unread 19-12-2007, 12:55
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: pic: Game hint
clues
So I guess the 12vdc battery on the robots is just there for counter balance?
2. the ribbon cable is not configured anywhere like a digital connection on the controller.
If you noticed by looking at the picture of the board, the connector on one end of the cable connects to the board at the matching plug. The other end of the cable is not terminated, allowing us to come up with our own connections designs to the RC.
3. the learning of a remote allows the newton field to use different codes from the curie field.
4. there are 4 outputs from the board. there are 4 corners on the field. 2 red remotes and 2 blue remotes would allow teams to trigger 4 release mechanisms.
jerry w
The rest of these speculations are distinctly possible.
I really would love to see more ideas on this thread about this boards possible uses, as long as they make sense based on what we know already.
  #518   Spotlight this post!
Unread 19-12-2007, 13:12
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: pic: Game hint
Uhhh the 12vdc battery connects to the RC board, which converts any digital output to 5vdc. I don't think the camera would run very well with 12vdc running through it!!
EDIT: Although this is the case I still think it will go on the bot.... but I also can see it being a field element... although I'm leaning more to it going on the bot
  #519   Spotlight this post!
Unread 19-12-2007, 13:21
billbo911's Avatar
Re: pic: Game hint
Well, the battery connects to a breaker, then to a distribution block and then to the RC. The distribution block make 12 vdc available to various devices: Victors, Relays, RC, Gear Tooth Sensors, IR Receiver Boards....
My point is, this device can quite easily be used on the robot, as well as being part of the field.
  #520   Spotlight this post!
Re: pic: Game hint
I am very interested in the white jack labeled 'J2'. I've mapped where the pins go.
Code:
J2	PIC 	Description
1	4	RA5/MCLR/VPP
2	14	VDD
3	5	VSS
4	13	RB7/PGD/T1OSI
5	12	RB6/PGC/T1OSO/T1CKI
6	X	X
Points of interest:
A) None of the possible i/o lines go to any header on the black jack. So we can assume that any IO coming from these has nothing to do with what the spec sheet we were given says.
B)Pins 2 and 3 are power.
C)Pin 1 could be input or a programming power.
D)The other used can be i/o, in circuit debugging, or programming.
I've never seen a chip flashed with such a gigantic connector (Usually there are just small contact pads, no?), and I do not think there would be need for debugging on a finished board.
So if I am correct in assuming that this jack is not meant for programing the chip, the white jack must be there to talk to something else, and will give off different signals than what the spec says so far.
Maybe we will see some kind of daughter board? Maybe this will hook up onto a field element?
  #521   Spotlight this post!
Unread 19-12-2007, 13:23
billbo911's Avatar
Re: pic: Game hint
Code:
J2	PIC 	Description
1	4	RA5/MCLR/VPP
2	14	VDD
3	5	VSS
4	13	RB7/PGD/T1OSI
6	X	X
Now that is what I'm looking for. Thanks Tom!!!
  #522   Spotlight this post!
Unread 19-12-2007, 13:24
FRC #1360
Re: pic: Game hint
Oh that's fine, I agree it can go ethier way. I hope someone can find a way to connect it to thier bot sometime soon! (Although I can see why people won't because we don't want to damage the hint lol)
  #523   Spotlight this post!
Unread 19-12-2007, 13:31
Re: pic: Game hint
I'm no electronics expert, but I think running this off of the 12V battery will all the crazy loads on it would be bad (but then again.... the RC is off the 12V...). Is this true?
Other than that fact which I don't quite understand, I think he is pretty dead on with his clues.... I'd agree with him more than any other guess so far.
  #524   Spotlight this post!
Unread 19-12-2007, 13:37
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: pic: Game hint
OK. I'll speculate as to what I believe this will be used for.
Many of us are assuming that there will be an autonomous mode because there has been an autonomous mode for the last few years. This year, I believe that instead of an autonomous mode there will be a timeframe (say 45 of the 135 seconds in a match) in which the drivers line of sight to the robot will be blocked (some sort of removable/droppable screen) and that the driver will only be able to navigate via a IR sensor grid, with 1 emitter in each corner of the field.
Since the viewing angle is only 60 degrees (+/- 30 degrees) there would be no overlap, and since the signal strength is proportional to how 'on axis' you are it would be fairly easy to navigate to a spot on the field.
Thoughts?
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
  #525   Spotlight this post!
Unread 19-12-2007, 13:42
Nuttyman54's Avatar
Mentor, Tactician
AKA: Evan "Numbers" Morrison
Re: pic: Game hint
Thoughts?
I thought of this too, but I'm pretty sure that the signal strength they're referring to is the input signal, not the output. I'm not an electrical guy, but from reading the document I gathered that the board only gives a digital output: either "I see my code" (+5v High) or "I don't see my code" (0v Low)
From the information that the RC would be getting (assuming this goes on the robot), there is no way to use the incoming signal strength to navigate.
Even if the board were giving out analog data corresponding to the signal strength, you'd have to have additional data from other sources to tell you whether your signal corresponded to the + or the - side of the angle off center.
I do believe the board will be used for navigation, but not in the sense that you are describing. (Though I very much wish it was)
pic: 2007 Game Hint? dlavery FRC Game Design 161 07-01-2007 13:42
pic: 2007 Game Piece Hint Wetzel Extra Discussion 39 07-01-2007 00:24
Offical Game Hint! Greg Needel Rumor Mill 117 21-12-2006 16:25
dlavery game hint nuggetsyl Rumor Mill 173 20-12-2006 22:00
Game hint?!?! Andy Grady Rumor Mill 67 30-12-2002 18:15
