Go to Post ...FIRST was created to change that world for the better. To presume that FIRST is simply here for your enjoyment is to demote it to nothing more than an expensive game... - RogerR [more]
Thread Tools Rating: Thread Rating: 25 votes, 4.84 average. Display Modes
  #526   Spotlight this post!
Unread 19-12-2007, 14:04
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: pic: Game hint
Since I don't have access to the board, I cannot test it, but my assumption (yeah I know) was that out0-3 were analog outputs.
Code:
Name Pin # Signal Description
+VIN 1, 2 Positive power supply voltage input. Voltage should be in the range 7-15 volts
DC. Your power supply will have to be independent, for example, a 6 x AA
battery pack, 9V battery, 12V battery, bench top supply, or other.
GND 3, 4 Negative power supply voltage input
OUT2 5 Output signal associated with third trained button
OUT1 6 Output signal associated with second trained button
OUT3 7 Output signal associated with fourth trained button
OUT0 8 Output signal associated with first trained button
NC 9, 10 Unused
And if we were allowed to use an array of these sensors you could quickly position where and what orientation you were on the playing field.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
  #527   Spotlight this post!
Unread 19-12-2007, 14:12
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: pic: Game hint
Sorry Bro,
According to the documentation available from FIRST:
"Each output provides a 100 mSec high (5V) pulse when its command is recognized."
No analog here, just one discrete output per input. Either High or Low.
Don't worry, I don't take the "me" part of your assumption personal.
  #528   Spotlight this post!
Unread 19-12-2007, 14:21
coolbotz coolbotz is offline
AKA: Joel Turner
FRC #0507 (Trojans)
coolbotz is an unknown quantity at this point
Cool Re: pic: Game hint
Pin description on J2 is a classic PIC -ICSP programming port.
  #529   Spotlight this post!
Unread 19-12-2007, 15:02
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: pic: Game hint
Originally Posted by billbo911 View Post
Sorry Bro,
Digital ... darn. And here I was hoping for a navagation aide.
Ah, well .
Thats what I get for assuming
___________________
- Tennyson, Ulysses
  #530   Spotlight this post!
Unread 19-12-2007, 16:29
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: pic: Game hint
I'm no electronics expert, but I think running this off of the 12V battery will all the crazy loads on it would be bad (but then again.... the RC is off the 12V...). Is this true?
It would still probably be okay with crazy loads as long as the voltage stays between the required 7.5V and 15V, which it should unless you run your main battery really really low (which is bad for the battery anyways).
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
  #531   Spotlight this post!
Unread 19-12-2007, 16:31
njamietech's Avatar
njamietech njamietech is offline
AXE 'EM JACKS
AKA: Neal Jamieson
FRC #0624 (CRyptonite)
njamietech is a glorious beacon of lightnjamietech is a glorious beacon of lightnjamietech is a glorious beacon of lightnjamietech is a glorious beacon of lightnjamietech is a glorious beacon of light
Send a message via MSN to njamietech
Re: pic: Game hint
Personally I don't think it will be part of the robot.
However I do like some of the Ideas that have been presented. Should make for an interesting year.
16 days 18 hours and 28 minutes till kickoff.
  #532   Spotlight this post!
Unread 19-12-2007, 17:01
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
Re: pic: Game hint
So I guess the 12vdc battery on the robots is just there for counter balance?
actually our team did use the battery that way one year.
come on Mr. Bill.
you have seen some of the things first has done in the past. maybe they forgot that the 3 pin connector for a digital input has +5 volts on one of the pins. so, why connect to and draw power from the breaker panel to operate this board?
did they need a 5 volt regulator on the board and on the robot controller?
i think you are looking at only half of the system here. for IR communication, the robot will have a transmitter. the IR reciever is the half that is placed on the field. we can use any old handheld remote for now. but we will have something else in the kit of parts.
jerry w
Happiest when people tell the truth... However, I am blessed with many friends.
  #533   Spotlight this post!
Unread 19-12-2007, 17:14
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: pic: Game hint
Like this? http://www.woot.com/Blog/BlogEntry.a...ogEntryId=3584
.99 cents + 5 dollar shipping from there when it was available.
I'm sure FIRST could have convinced Woot to sell them a ton of them for even cheaper.
(btw, I love the time on the timestamp in that summary about it.)
  #534   Spotlight this post!
Unread 19-12-2007, 17:21
billbo911's Avatar
Re: pic: Game hint
Come on Mr. Bill.
You have seen some of the things first has done in the past. Maybe they forgot that the 3 pin connector for a digital input has +5 volts on one of the pins. So, why connect to and draw power from the breaker panel to operate this board?
Did they need a 5 volt regulator on the board and on the robot controller?
I think you are looking at only half of the system here. for IR communication, the robot will have a transmitter. the IR receiver is the half that is placed on the field. we can use any old handheld remote for now. but we will have something else in the kit of parts.
jerry w
We've been known to use a battery that way as well. Why waste that much weight and compensate for it elsewhere?
I really doubt FIRST would "forget" +5vdc is there. But, then again, the GTS from the 2005 KOP required +12vdc. as well, and it had to come from the battery. Besides, here are some quotes from the Users Guide:
"Assuming a 12VDC supply,"
and
"Voltage should be in the range 7-15 volts
battery pack, 9V battery, 12V battery....."
So, if the robot will have the transmitter, then why manufacture one receiver board, at a minimum, per team and also spend the money and manpower on shipping?
As for a transmitter being in the KOP, I definitely agree, that is a possibility!
I guess all this back and forth is fine for now. We both will know for sure come Kick Off.
  #535   Spotlight this post!
Unread 19-12-2007, 17:25
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Re: pic: Game hint
So, I was thinking. Could it be possible even though all rational people might say this game will never happen ... Does IR work underwater? Or more importantly, through an air-water interface? ... sigh ... I was going to sleep over the holidays, now I'm wrapped up in the mayhem too ...
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
  #536   Spotlight this post!
Unread 19-12-2007, 17:40
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: pic: Game hint
Light does pass through the air water barrier but it bends as it does so.
___________________
- Tennyson, Ulysses
  #537   Spotlight this post!
Unread 19-12-2007, 18:03
in between teams
AKA: Luke Van Oort
Re: pic: Game hint
I know pretty much for certain we'll get some IR emitters in the kit. Anyone ever stalled a Fisher-Price? (sorry, couldn't resist)
Team 1219: 2009 - Mentor
  #538   Spotlight this post!
Unread 19-12-2007, 18:06
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: pic: Game hint
Water's refractive index is about 4/3. Light originating on the water side will be partially reflected (back into the water) and partially refracted (into the air) at angles given by Snell's Law. Light originating in the water and incident on the surface at an angle greater than about 49 degrees will be totally reflected back into the water.
So some underwater positions will permit better transmission of IR than others.
Richard Wallace
since 2003
  #539   Spotlight this post!
Unread 19-12-2007, 18:18
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: pic: Game hint
I wasn't going to get into the math of it because it's highly unlikely that we'll need to transmit (or recieve) through the air/water barrier.
Also, you will most likely be able to transmit at greater angles because the surface of water will (most likely) never be a perfect plane.
Snell's law could come into play though if you tried to protect your sensor with polycarbonate ... which also makes me wonder if polycarbonate is opaque to IR ... Hmmmmm
___________________
- Tennyson, Ulysses
  #540   Spotlight this post!
Unread 19-12-2007, 18:25
mizitchell's Avatar
mizitchell mizitchell is offline
AKA: Mitch
FRC #2075 (Enigma)
mizitchell is on a distinguished road
Re: pic: Game hint
Polycarbonate isn't opaque to IR
I think...
pic: 2007 Game Hint? dlavery FRC Game Design 161 07-01-2007 13:42
pic: 2007 Game Piece Hint Wetzel Extra Discussion 39 07-01-2007 00:24
Offical Game Hint! Greg Needel Rumor Mill 117 21-12-2006 16:25
dlavery game hint nuggetsyl Rumor Mill 173 20-12-2006 22:00
Game hint?!?! Andy Grady Rumor Mill 67 30-12-2002 18:15
