#526
Re: pic: Game hint
Since I don't have access to the board, I cannot test it, but my assumption (yeah I know) was that out0-3 were analog outputs.
Code:
Name Pin # Signal Description +VIN 1, 2 Positive power supply voltage input. Voltage should be in the range 7-15 volts DC. Your power supply will have to be independent, for example, a 6 x AA battery pack, 9V battery, 12V battery, bench top supply, or other. GND 3, 4 Negative power supply voltage input OUT2 5 Output signal associated with third trained button OUT1 6 Output signal associated with second trained button OUT3 7 Output signal associated with fourth trained button OUT0 8 Output signal associated with first trained button NC 9, 10 Unused |
#527
Re: pic: Game hint
According to the documentation available from FIRST: "Each output provides a 100 mSec high (5V) pulse when its command is recognized." No analog here, just one discrete output per input. Either High or Low. Don't worry, I don't take the "me" part of your assumption personal. ![]() |
#528
Pin description on J2 is a classic PIC -ICSP programming port.
#529
Re: pic: Game hint
Ah, well . Thats what I get for assuming ![]() |
#530
Re: pic: Game hint
It would still probably be okay with crazy loads as long as the voltage stays between the required 7.5V and 15V, which it should unless you run your main battery really really low (which is bad for the battery anyways).
#531
Re: pic: Game hint
Personally I don't think it will be part of the robot.
However I do like some of the Ideas that have been presented. Should make for an interesting year. 16 days 18 hours and 28 minutes till kickoff. ![]() |
#532
Re: pic: Game hint
come on Mr. Bill. you have seen some of the things first has done in the past. maybe they forgot that the 3 pin connector for a digital input has +5 volts on one of the pins. so, why connect to and draw power from the breaker panel to operate this board? did they need a 5 volt regulator on the board and on the robot controller? i think you are looking at only half of the system here. for IR communication, the robot will have a transmitter. the IR reciever is the half that is placed on the field. we can use any old handheld remote for now. but we will have something else in the kit of parts. jerry w |
#533
Re: pic: Game hint
.99 cents + 5 dollar shipping from there when it was available. I'm sure FIRST could have convinced Woot to sell them a ton of them for even cheaper. ![]() (btw, I love the time on the timestamp in that summary about it.) ![]() |
#534
Re: pic: Game hint
We've been known to use a battery that way as well. Why waste that much weight and compensate for it elsewhere? I really doubt FIRST would "forget" +5vdc is there. But, then again, the GTS from the 2005 KOP required +12vdc. as well, and it had to come from the battery. Besides, here are some quotes from the Users Guide: Quote:
As for a transmitter being in the KOP, I definitely agree, that is a possibility! I guess all this back and forth is fine for now. We both will know for sure come Kick Off. ![]() |
#535
Re: pic: Game hint
So, I was thinking. Could it be possible even though all rational people might say this game will never happen ... Does IR work underwater? Or more importantly, through an air-water interface? ... sigh ... I was going to sleep over the holidays, now I'm wrapped up in the mayhem too ...
![]() Last edited by Rich Kressly : 19-12-2007 at 17:27. |
#536
Re: pic: Game hint
Re: pic: Game hint
I know pretty much for certain we'll get some IR emitters in the kit. Anyone ever stalled a Fisher-Price?
(sorry, couldn't resist) |
#538
Re: pic: Game hint
So some underwater positions will permit better transmission of IR than others. Last edited by Richard Wallace : 19-12-2007 at 18:09. |
#539
Re: pic: Game hint
Also, you will most likely be able to transmit at greater angles because the surface of water will (most likely) never be a perfect plane. Snell's law could come into play though if you tried to protect your sensor with polycarbonate ... which also makes me wonder if polycarbonate is opaque to IR ... Hmmmmm |
#540
Re: pic: Game hint
Polycarbonate isn't opaque to IR
I think... |
| pic: 2007 Game Hint? | dlavery | FRC Game Design | 161 | 07-01-2007 13:42 |
| pic: 2007 Game Piece Hint | Wetzel | Extra Discussion | 39 | 07-01-2007 00:24 |
| Offical Game Hint! | Greg Needel | Rumor Mill | 117 | 21-12-2006 16:25 |
| dlavery game hint | nuggetsyl | Rumor Mill | 173 | 20-12-2006 22:00 |
| Game hint?!?! | Andy Grady | Rumor Mill | 67 | 30-12-2002 18:15 |
