Go to Post I've ridden the real Segway many times and I think it is a truly remarkable machine and worth every cent (if you have enough cents to spend on it). - sanddrag [more]
Unread 19-12-2007, 20:04
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
Re: pic: Crab Drive Frame
Great ideas and nice CAD, every body has a hundred ways of doing it. It doesn't mater how you do it as long as it works for you. A thought I had with our design is to have the arm rotate with the drive directions. No mater what direction you go the arm will be going that direction. Doing that you can use one joystick, left right drives the turn motors, forward back drives the CIM's. We don't need to rotate the direction of the robot if the arm is always going the direction you are going. That really makes it easy, well except designing an arm that can go 360.
pic: Ultimate Vex crab drive 2 cire Extra Discussion 9 01-06-2007 16:46
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
pic: Tredded-Tripedal-Modular-Crab-Drive CD47-Bot Robot Showcase 11 28-04-2004 22:06
pic: Coaxial Lego Crab drive CD47-Bot Robot Showcase 11 04-11-2003 14:45
