Go to Post "We don't build the robots, we build the robot builders." - [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 12-20-2007, 05:32 PM
run the trap!!!
Team Role: Human Player
pic: Team 100 Prototype Base - Underside
Unread 12-20-2007, 05:33 PM
CraigHickman
Re: pic: Team 100 Prototype Base - Underside
55 pounds is pretty heavy... Why the bosch extrusion, as opposed to something lighter, such as 1x1 box extrusion, or C channel?
Looks nice!
Last edited by CraigHickman : 12-20-2007 at 05:47 PM. Reason: answered my own question.
Unread 12-20-2007, 05:43 PM
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Hey hey show a little modesty! We don't go around turning YOU upside down and taking pictures!
*chuckle* Anyhow, on the more nuts-and-bolts side of life, for what you're building there, why not use a Kit Bot frame from IFI? It's rock solid strong, really light, and sports 1" center free fit holes accomadating 1/4"-20s. I know it sounds tacky to use a kitbot frame... but really, its tough to beat for strength/weight balance.
Are the transmissions AndyMarks? Hard to tell from here.
Looking good... NICE wheels, did you all make them?
-q
Electrical Engineer Illini
Unread 12-20-2007, 05:47 PM
pakratt1991's Avatar
pakratt1991 pakratt1991 is offline
AKA: Tim L.
FRC #0997 (Spartan Robotics)
pakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nice
Send a message via AIM to pakratt1991 Send a message via MSN to pakratt1991 Send a message via Yahoo to pakratt1991
Wow 55 pounds is pretty beefy, I agree with Manuallabor, go with some extrusion, either 1X2 or if you like the shape if the bosch extrusion you could go with a 1X2. Although this might require you to build in some cross bracings. I know that bosch stuff is pretty solid.
Are you planning on using the old andymark transmissions or just waiting on build season to order some super shifters?
On a side note, I was able to shift both of our transmissions last year using only 1 of the pistons with an extender build on. I can include some pics if you're interested. Although our transmissions were modified to be thinner, and thus lighter, I do not know if you can do it with an unmodified set, but might be interesting to look into anyways.
2010 Oregon Autodesk Regional Winner (997, 2130, 1515) (Event Volunteer)
2008 UC Davis Semi-Finalists
2007 Championship Semi-Finalist (494, 254, 997)
2007 Davis Sacramento regional Champs (100, 997, 1458)
2007 PNW regional, Champs (997, 272, 1087)
Unread 12-20-2007, 05:50 PM
CraigHickman
Shifting with only 1 cylinder has its perks, but it's not for every system. If your transmissions are centered in your bot, it makes it annoying to rout different subsystems around the cylinders, and it also limits putting a chassis member there. We did this for our 2k5 bot, AimBot. It works best if the transmissions are direct driving one of the front wheels (or in your case, front pulley.)
PS, pakratt, wanna have sam shoot me an email? We're doing pre season planning, and I'm interested in a few details for the upcoming season. Thanks!
Unread 12-20-2007, 05:58 PM
AKA: Tim L.
Will do, A mentor and a few students (including myself) are heading up to his shop on the 28th, so we will know much more after that.
I guess he plans on modifying some super shifters and using them, there is a little bit of modification needed to make them mirror one another, we also plan to drop a couple of pounds from the trannys.
Unread 12-20-2007, 06:27 PM
run the trap!!!
I'm a little confused why you all think this is so heavy. That weight includes our entire electronics board; drive motors, air-tank, and compressor. There is a full 65 lbs. available for a scoring device. Last year's drive train weighed 50 lbs. without electronics, pneumatics and the upper frame! And we never had any weight issues!
Originally Posted by Qbranch View Post
...and sports 1" center free fit holes accomadating 1/4"-20s...
I hate those little holes. They are always exactly where you don't want them to be! Which means that you have to create an oval-shaped hole to bolt on the desired part.
This is exactly why we use the bosch. The 80/20 has linear grooves that make attaching anything a breeze. It also makes tensioning chains very easy, just slide the pillow blocks down the grooves and tighten the bolts. We only use it in the base to save weight.
Our team used the Kit Bot in 2006 and it was a big pain. There just isn't a good way to keep things adjustable with it.
As for the wheels we bought them from Andy Mark. Our little CNC isn't powerful enough to make a wheel in a reasonable amount of time. It would take all day to make one wheel! The AM Performance wheels are great, but they're really expensive. Next year we'll probably just use two of them in the middle and the kit wheels on the corners to save weight and money
-Philip J. Fry
Unread 12-20-2007, 07:43 PM
CraigHickman
Our previous drive base(07 season), with electronics, pneumatics, and motors was 45 pounds, and it was too heavy for me. My current drive designs, with all materials set correctly, weigh in around 38-40. The heavy end is the Crab, which is 50. Just because the drive base is light, doesn't mean the weight of the bot will be high. You can always design low, with very light upper members.
Unread 12-20-2007, 07:56 PM
DonRotolo's Avatar
Back to humble
FRC #0832
Nice concept. Those corner braces will eliminate most of the need for bracing, and the electronics board can go a long way towards rigidity as well.
Is that #25 chain or #35?
Thanks,
Don
Unread 12-20-2007, 08:02 PM
MrForbes MrForbes is offline
Why is that too heavy? the 100 robot fell over in a match (with some help )....seems to me that means the drive base could have been heavier, which would have forced them to keep weight off the top of the robot, and make the whole thing more stable.
Weight down low isn't necessarily a bad thing.
Unread 12-20-2007, 08:03 PM
Engineering Mentor
FRC #0254
Thumbs up Re: pic: Team 100 Prototype Base - Underside
I wouldn't worry about it. I think it's perfectly reasonable. You've also got the two larger CIMs on there which weigh considerably more than the smaller ones.
You guys need to ease up and give them some credit. I think this is one of the better put together systems I have seen posted on CD in a while - not to mention they actually succesfully built it and tested it. It is also one of the more creative solutions that I have seen...
It's pretty sad that I'll be the first one in this thread (Edit: aside from the last two) to give them a thumbs up on the whole thing. There isnt much I would change, as I am sure they have seen the alternatives and have weighed those options against this chosen design.
-Travis Covington
Unread 12-20-2007, 08:16 PM
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Looks great! I like the simplicity of it, particulartly the lack of chain tensioners. Those axle mounts seem like a nice simple solution as opposed to the CNCd ones we usually see. Nice work.
The weight sounds about right, too. If you need more than 65 pounds for your manipulator, then the drivetrain isn't the part you should be redesigning...
Unread 12-20-2007, 09:18 PM
Dan Petrovic's Avatar
FRC #0166 (Chop Shop)
-q
I wouldn't really consider the kitbot frame rock solid strong...
C-channel has about half as much torsional strength as box tubing even though it has only one less side.
Unread 12-20-2007, 09:39 PM
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I'm happy to see you all got this built. Prototyping in the off-season is an invaluable experience for new and experienced team members, allows you a chance to safely try new ideas, and helps you to work out the kinks in your manufacturing processes. Even if, on the day of kick-off, you have to throw this design out (...and I hope that you won't...) or rebuild all of your modeling and design work from the ground up, it's worth the effort.
55 lbs. is respectable -- especially with a pneumatics system on board and two of those large CIM motors. That alone probably represents ~15 lbs. of your total weight. The 1x2" extruded profile is a bit heavier than rectangular tubing, yes, but that penalty may be worth the time saved in labor. We finished our prototype chassis, for the most part, back in early November. It's 30 lbs. -- but that's with two motors and no pneumatics system -- and it required considerably more manufacturing effort. The most recent iteration incorporates a lot of the features y'all have here and, though it's a few pounds heavier, involves far, far less work. It's a worthwhile compromise.
If you don't mind answering a few questions:
-- From what are the bearing blocks made? They look like they're 1/4" thick, overall dimensions of 2.25 x 1.5. McMaster-Carr, nor onlinemetals.com, seem to carry stock of these or similar dimension. Are they custom made?
-- What machining work was done to the 1x2 extrusion to accomodate the axles?
-- Where'd you find 1/2" bore, keyed sprockets for #25 chain? What were lead times and cost like?
Thanks for sharing this.
--Madison--
...down at the Ozdust!
Unread 12-20-2007, 10:17 PM
run the trap!!!
Our team did a stress analysis a while back and determined that the kitbot was actually quite strong. I think its infamous reputation comes from teams cutting notches in it and weakening its structure. Left in its original state it is very strong.
No problem
--Wow that’s the exact dimensions ! We searched and searched for channel stock that came in these dimensions, but it didn't exist . So we just purchased a 2.25 x 1.5 block from a local metal supplier and machined a 1 x 2 slot in it. It took forever on our little mill, but our sponsor will probably be able to get it done in an afternoon.
--We just cut two 0.75" long slots on either end with a 0.75" end-mill. The center slot is vertical, allowing the center wheel to be raised or lowered an 1/8 of an inch.
--McMaster Carr. We had to machine them thinner and broach them, but it wasn't too hard. Just like everything else they carry the sprockets were cheap and arrived soon
-Philip J. Fry
pic: Team 100 Prototype Base =Martin=Taylor= Extra Discussion 8 12-21-2007 01:06 AM
pic: FRC294 Prototype base almost done AdamHeard Extra Discussion 24 11-29-2007 01:12 AM
pic: Team 100 Prototype Base =Martin=Taylor= Extra Discussion 11 10-10-2007 07:39 AM
pic: 294 Prototype Base frame rails Borisdamole Extra Discussion 6 09-17-2007 06:19 PM
pic: FRC294 Prototype base AdamHeard Extra Discussion 18 09-07-2007 03:22 PM
