| Thread Tools |
Rating:
Display Modes |
#601
Re: pic: Game hint
Maybe a complex version of laser tag with a capture the flag objective? a win/loose game would be unlikely though because penalty points would have to be assessed real time.
#602
are therre ant threads longer thin this one?
#603
Re: pic: Game hint
lol probably this one has only been open for a week or so (6 days actually) so I bet ones are out there that are longer. (now getting this many posts this fast, it probably takes the cake
)As for laser tag, I think it would be cool, but Interference is still a huge problem and how would you play laser capture the flag??? |
#604
Re: pic: Game hint
The longest threads are in the Games/Trivia sub-forum.
Word association is at 9,247 posts |
#605
Re: pic: Game hint
i have already posted 4 clues. anyone who is serious about solving this puzzle needs to examine the board. CLUE# 5 the programmers might best like this clue. on the robot controller the digital inputs are the most used connections for feedback devices. we often come close to using all these inputs. so why would first design a board with 4 ouputs? only a single remote can be detected at any time. thus only a single output line will pulse. this provides 4 pieces of information. it takes only 2 bits to hold 4 different values. the board should have 2 signal lines if the robot controller is to use this IR detector. therefore, this will not be on the robot. we should try to determine what field-device could be activated by the 100 ms pulse from this board. there must be 4 gates, or 4 containers, or 4 of something. jerry w |
#606
Re: pic: Game hint
On my poker forum we have a thread with 258,904 posts, so far.
#607
Re: pic: Game hint
While it is true that the reciever board we got can only read 1 signal at a time, and that there 4 different types of signals that can be read, there are 5 possible conditions coming out of the reciever. And they are: Out0=on,Out1=on,Out2=on,Out3=on, and no signal recieved. Therefore 2 bits will not cover all of the possible outputs from the board. |
#608
Re: pic: Game hint
You assume that we're using the same FRC controller. If the robot were the IR transmitter there would still need to be an IR encoding board or each team will need to write code to encode the IR signals. |
#609
Re: pic: Game hint
As per new email from FIRST:
EDIT: The first thing I thought of was a set of lat/longitude coordinates. Using the first two, + being north on the first and - being west on the second, I get Copley Square in Boston, right in front of the John Hancock Tower. However, probably just some settings for the IR sensor... but who knows? Last edited by Syncopation : 21-12-2007 at 17:12. |
#610
Re: pic: Game hint
342.24 as an elevation measurement....
342.24 inches = 28.52 feet 342.24 cm = 11.23 feet the elevation of Boston is ~19 feet above sea level, so either one of those is plausible for the ground level of Copley Square EDIT: Copley Sq is about 16 feet above sea level, so it's not the ground elevation. HOWEVER, if you look at the satelite view in Google Maps, it appears to be pointing DIRECTLY at a statue or post of some sort. This could be the elevation of the top of the statue, a plaque on the statue....anyone want to go take a look? (I would, but I'm in California at the present time) EDIT #2: Statue appears to be of John Singleton Copley, the square's namesake. Famous for his paintings, parents were traders. Theres more on his wiki page. Hint could also just as easily involve the physical statue attributes, or his name (Singletons anyone?) EDIT#3: Copley Square is the official finish line for the Boston Marathon (Credit to Ruth of 1735 for this one) Last edited by Nuttyman54 : 21-12-2007 at 17:30. |
#611
Re: pic: Game hint
wow.... are you guys all physic... that was exactly the same things said in the email blast thread lmao
#612
Re: pic: Game hint
Discussion about the second hint has moved here
http://www.chiefdelphi.com/forums/sh...ad.php?t=60297 |
#613
Re: pic: Game hint
I believe this will follow two rules, kind of like the camera has in the past. 1. I highly doubt that this board is going to be mission-critical. 2. It'll be nice if you have it, but some teams will not have the ability to make it work. Therefore, any advantages gained from having it must not be so large as to guarantee a win. I'm thinking something like what turtlecoach described above. Example 1: there are four identical bins, each with a transmitter on them that you have to deposit balls into. One or two of the four bins has the transmitter active. Depositing balls into the one or two transmitter-active bins scores you 5 points/ball. Depositing balls into any other bin scores you 2 points/ball. Specific point values notwithstanding. Example 2: 4 identical bins, each with a transmitter. Each bin is numbered, the numbers remain identical throughout every match. (I.E. bin #1 will always be the bin closest to the blue alliance station) They all start transmitting the same, coded signal. This signal will identify a particular bin. Depositing balls into the indicated bin will result in more points than depositing balls into any other bin. Sorry if I repeated anything that's already been said. I didn't read all 41 pages before posting, just the first and last few. |
#614
Re: pic: Game hint
i knew this was a weak clue but forgot why. it doesnt invalidate the conclusion. however, having 3 digital inputs is not much better than 4. jerry w |
#615
Re: pic: Game hint
This might have been pointed out earlier in the thread, but i thought i would say it myself...2004 game - there was a LED receiver that was used in auto. mode. I want to say that this is a re-try of that? but with a more sophisticated device?
| pic: 2007 Game Hint? | dlavery | FRC Game Design | 161 | 07-01-2007 13:42 |
| pic: 2007 Game Piece Hint | Wetzel | Extra Discussion | 39 | 07-01-2007 00:24 |
| Offical Game Hint! | Greg Needel | Rumor Mill | 117 | 21-12-2006 16:25 |
| dlavery game hint | nuggetsyl | Rumor Mill | 173 | 20-12-2006 22:00 |
| Game hint?!?! | Andy Grady | Rumor Mill | 67 | 30-12-2002 18:15 |
