Go to Post I'm all for an aggressive game, but lets not crack each others lexan. - Molten [more]
Unread 27-12-2007, 16:09
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
pic: AM Supershifter mount / cntr axle saddle rev 3
Unread 27-12-2007, 16:15
run the trap!!!
Team Role: Human Player
Re: pic: AM Supershifter mount / cntr axle saddle rev 3
I sure hope you aren’t expecting to machine that out of a solid block. If you can find a piece of boxed aluminum the right size it shouldn't be that hard though.
-Philip J. Fry
Unread 28-12-2007, 02:57
artdutra04's Avatar
VEX Robotics Engineer
Is this going to be milled on a conventional milling machine? Or will it be fabricated via another method? (I'm assuming that it's going to be milled, due to the lack of bend radaii on the edges that would be there if fabricated from sheet metal (via laserjet, waterjet, or turret/punch) and then bent up.)
If it is going to be fabricated via a conventional [CNC] milling machine, then why make it such an odd shape when you can make it more "squareish" to make it easier (and faster) to mill?
(E.g. leave the entire face-mounting side square, and mill two pockets in it (one to the side of the axle, one underneath).
Art Dutra IV
世上无难事,只怕有心人.
Unread 28-12-2007, 09:31
Version 1 was very much a square block. It came in pretty heavy so I then reworked the design to reduce weight. I am now considering a design to make this a two piece - bolt together component for ease of milling. In fact, I realized that I don't need the bearing on the transmission side of things as the shaft is supported by the exact same bearing coming out of the AM transmission. I am also considering not bolting to all four through bolts on the transmission. Anybody have any thoughts as to the strength of just bolting to the AM supershifter with just two bolts
This will take me a few days to design as I have to get back to my duties of designing a new closet for the bedroom. (Cut the lumber yesterday) Need to finish before FIRST season or else
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 28-12-2007, 14:34
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Oh man. The possibility of one of our newest sponsors having fun with that piece & making it out of bent sheetmetal kinda excites me...
Maybe we'll borrow your design this year, who knows?
Unread 28-12-2007, 15:19
RedHeadRobotics's Avatar
RedHeadRobotics RedHeadRobotics is offline
AKA: Brigid
FRC #2081 (Icarus)
RedHeadRobotics will become famous soon enoughRedHeadRobotics will become famous soon enough
Although this idea sounds a bit far fetched, the layout seems to make a lot more sense than Copley Square in Boston
Unread 28-12-2007, 15:23
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I think you may see some binding trouble on the shaft if you try to make it pass through a third or fourth bearing once it's left the AM SuperShifter. Because you're bolting the transmission directly to this, there's no room for misalignment, so keep that in mind.
--Madison--
...down at the Ozdust!
Unread 28-12-2007, 18:41
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
You don’t have to use just the through bolts. There is plenty of space inside the SS to drill a couple of mounting holes.
Good luck, I like your design.
Hex vs. Dead axle GMKlenklen Technical Discussion 5 16-12-2006 19:58
pic: Mecanum Wheel Project - Rev. D Madison Technical Discussion 17 07-08-2006 18:19
pic: Mecanum Wheel Project - Rev. E Madison Technical Discussion 8 13-07-2006 13:31
axle problems illumanat'i Technical Discussion 8 02-02-2003 02:01
axle thread size archiver 2000 3 23-06-2002 22:50
