Re: pic: Off season project
Originally Posted by richardmcc2
Wow that looks sweet.....what kind of gearboxes are you using? And where did you get the bevel gears? I can't really seem to see any gears or chain going to the wheels, I guess you just did a good job of making it compact
Link to http://team1322.org/joeway.htm#build3 some drawings of the gears and pictues. We used some gears from the 2004 season gear box and some gears from the 2006 gear box. If you check them out you will find it was easy to set up the gearing. The hard part was putting an idler sprocket in to tension the chain, also to make the chain wrap around the drive gear a little more.
FRC Team site http://team1322.org/
FTC Lightining Boltz 5954, Thunder Botz 7032 http://team1322.org/vex.htm
