Go to Post FIRST gives everyone lots of practice in getting used to late nights. - waialua359 [more]
Unread 30-12-2007, 18:40
artdutra04's Avatar
VEX Robotics Engineer
Re: pic: Front / Rear bearing saddles rev 2
Originally Posted by Andrew Schuetze View Post
Now that I have my design,
To make machining easier, what if I made this a three piece bolt together assembly? It would have two identical side plates and then the top piece. Maybe four tapped holes for #8 or #10 machine screws or clearance holes for the same with nylon lock nuts at the end of 2" bolts... I wouldn't know how to calculate the bolt strength needed to deal with the loads.
Does your machine shop have welding capabilities?
When my father and myself were working on the Mountain Dewbot, we machined a bunch of brackets similar to the one in this thread out of 0.25" aluminum plate, tapped and threaded for 6-32 hardware to hold it square, and had the seams welded. As long as you bevel the edges (after tapping) where they'll weld, you'll get good penetration and have a strong joint.
Art Dutra IV
世上无难事,只怕有心人.
pic: Rear view of our 07 'bot Cody Carey Robot Showcase 7 16-02-2007 12:29
pic: Team 207's Rear drivetrain Metalcrafters Robot Showcase 2 21-02-2006 22:51
pic: 237 rear window sticker Jay H 237 Extra Discussion 2 28-02-2005 12:06
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
pic: 857 rear view programming CD47-Bot Robot Showcase 1 25-02-2003 22:24
