Go to Post While Grace will carry you through good times and victory, Professionalism will carry you through hard times and defeat. - Venkatesh [more]
Unread 30-12-2007, 19:02
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Re: pic: 499 Prototype drivetrain final layout
The center axle is 0.125" lower and not adjustable. The outside axles have 1" slots which will allow for chain tensioning. The chain will be on the wheel side as there is not room between the transmission and frame rail. A universal hub will drive the center wheel and sprockets attached to the wheel or a second hub will drive the outer wheels via attached sprockets. The outer axles are dead axles which saves me bearing mounts on the saddles. The use of #25 chain is due to weight considerations. I'm told by other posters in a seperate thread that teams have been successful with #25 as long as tension is dealt with appropriately. If I can get some 1020 in the shop within a week or so, I will adjust the saddle widths to the smaller profile which will drop a few pounds and then we won't have to worry about weight as much and can use #35 chain.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
1541 Prototype Drivetrain bombadier337 Technical Discussion 12 23-01-2006 08:26
pic: The final...final match CD47-Bot Extra Discussion 4 17-04-2003 16:24
Image Discuss: Team 773 Drivetrain Prototype CD47-Bot Extra Discussion 5 27-01-2003 18:46
