Go to Post Innovating for the sake of innovating, reinventing the wheel is probably the second biggest pitfall you can fall into when designing an FRC robot, if the wheel is already a very optimized, good solution. - Chris is me [more]
Unread 31-12-2007, 15:09
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: pic: 499 Prototype drivetrain final layout
I would be highly interested in a sort of synthesis of these two designs. I like Madison's design for the lightness of the frame components, but I think there's a lot of advantage to the style of bearing blocks the Andrew has designed. As I understand it, the main purpose of 8020 is to simplify chain tensioning, and Andrew's block only need three screws on the top for adjustments. Madison's, while somewhat lighter, would take require loosening 2 screws outside the frame and 2 screws inside the frame, which seems more troublesome to me. Admittedly, the loading on Andrew's blocks wouldn't be quite what you'd like, but I don't think it would really present a problem. If Madison's using 1515 Lite instead of 1010 on those side rails you could probably bolt them straight on.
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
1541 Prototype Drivetrain bombadier337 Technical Discussion 12 23-01-2006 08:26
pic: The final...final match CD47-Bot Extra Discussion 4 17-04-2003 16:24
Image Discuss: Team 773 Drivetrain Prototype CD47-Bot Extra Discussion 5 27-01-2003 18:46
