Go to Post you are never an alumni of FIRST, you can always be there, mentoring, learning, creating. - KelliV [more]
Unread 01-01-2008, 12:10
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Re: pic: 6WD Design Iteration
Maddie,
As you probably know, I am nuts about high current drive systems. Six wheels on the floor is one of those, but I think having the omni wheels in front will go a long way to helping with the current problem. I bet you are planning on setting the middle wheels a little lower as well. But, I bet if you have the ability to move the center trucks back about six inches, you can keep all wheels on the ground, lower the current in turns, still have a stable platform for pushing from the side and have plenty of traction in the forward and reverse directions.
I very much like the approach of minimum machining. I am sure there will be some interest in this design for many teams. If we are at an event together, please drag me over to look at this design, should you use it. I would love to see it in action.
Al
WB9UVJ
www.wildstang.org
________________________
pic: another iteration Aren_Hill Extra Discussion 8 20-12-2007 01:28
pic: Isometric View of A 6WD module Cody Carey Extra Discussion 8 04-01-2007 17:19
6WD? Alex Cormier FIRST Tech Challenge 14 17-04-2006 22:10
pic: Team 488 Arm Prototype -- Iteration 4 Madison Extra Discussion 1 13-02-2005 01:54
