Go to Post Winning the robot part of the competition is not about learning or doing unneccesary work. It works just like "winning" in industry. - Max Lobovsky [more]
Unread 01-01-2008, 23:51
EricH EricH is offline
Re: pic: 2 speed tranny
Originally Posted by chris31 View Post
Its hard for me to judge from the angle, but it looks like you will not have much room for an output sprocket due to the encoder. I could just be look at a bad angle.
It does look that way. However, I'd say they aren't planning on having a sprocket directly attached to the output shaft. The encoder and shifter would get in the way except in a fairly narrow angle. Plus that's a pretty small sprocket. I'm going to guess that they use a coupler to a longer shaft that can either direct drive a wheel or connect to a sprocket.
My question is, are the side plates going to be hogged out to save weight? Those are some heavy trannies!
pic: 1662's test tranny 5 M4 Sherman Technical Discussion 4 17-06-2006 01:44
pic: Dual FP KOP Tranny Andy Brockway Robot Showcase 5 06-02-2006 11:41
pic: Team 1501 Tranny Wayne Doenges Robot Showcase 8 19-02-2005 02:52
It's Back! 4-Speed Shift-On-The-Fly Tranny. New and Improved! Travis Covington Robot Showcase 16 16-02-2005 18:28
Team 968's technokat inspired 4 speed tranny Travis Covington Robot Showcase 12 01-03-2004 10:06
