Originally Posted by lukevanoort
Is there a reason you switched to aluminum side plates and returned to bronze bushings?
The plastic plates we used last year flexed and allowed everything to become misaligned. In years past, everything spun on brass bushings except the motor combiner. On this design, everything is on bearings except the shaft for the smash shifting, however the gear cluster on that shaft has bearings inside of it.
Originally Posted by chris31
Its hard for me to judge from the angle, but it looks like you will not have much room for an output sprocket due to the encoder. I could just be look at a bad angle. Whats the gear ratios?
The transmission is designed to be modular so we've put all the drive sprockets on the same shafts as the wheels (6wd).
http://www.flickr.com/photos/jdebner...7594547502324/
here's a pic of last years bot. you can kind of see how where the tranny links to the center axel.
.925:35 in low and 3:35 in high
