Go to Post I've got a couple team members who have an incredible knack for destroying robot parts... - Tom Line [more]
Unread 02-01-2008, 00:08
EricH EricH is offline
Re: pic: 2 speed tranny
Originally Posted by ADZDEBLICK View Post
If needed yes, but I was under the impression that 3.32lbs per side was light.
Weight wise, you're carrying about 3 small CIM motors with the drive motors attached. Mind you, if you can get the rest of the robot to also fit in the weight budget, I'd rather have the weight in the trannies where it's low to the ground. If not, remove some of the "extra" wall material away from the bearing areas. There's a lot of weight there.
pic: 1662's test tranny 5 M4 Sherman Technical Discussion 4 17-06-2006 01:44
pic: Dual FP KOP Tranny Andy Brockway Robot Showcase 5 06-02-2006 11:41
pic: Team 1501 Tranny Wayne Doenges Robot Showcase 8 19-02-2005 02:52
It's Back! 4-Speed Shift-On-The-Fly Tranny. New and Improved! Travis Covington Robot Showcase 16 16-02-2005 18:28
Team 968's technokat inspired 4 speed tranny Travis Covington Robot Showcase 12 01-03-2004 10:06
