Go to Post The rules are the rules, but if the rules get so ridiculous some of us may choose not to play anymore and that is the bigger shame. - Paul Copioli [more]
Unread 02-01-2008, 00:19
in between teams
AKA: Luke Van Oort
Re: pic: 2 speed tranny
Weight wise, you're carrying about 3 small CIM motors with the drive motors attached. Mind you, if you can get the rest of the robot to also fit in the weight budget, I'd rather have the weight in the trannies where it's low to the ground. If not, remove some of the "extra" wall material away from the bearing areas. There's a lot of weight there.
I wouldn't go so far as to say 'a lot of weight.' I can see this getting into the mid to high two pound range. That's, at most, a 1lb saving for the entire robot at the cost of significantly increase machining time. As drawn, the plates could be made on 195's EDM, if you add pocketing that significantly increases manufacturing time and adds another machine. (unless it is already being milled, then it just adds time)
If that middle plate can be eliminated though, that would save weight and make it easier to machine (one less part). I can't really see what that plate's purpose is so I don't know how easy that would be.
Team 1219: 2009 - Mentor
pic: 1662's test tranny 5 M4 Sherman Technical Discussion 4 17-06-2006 01:44
pic: Dual FP KOP Tranny Andy Brockway Robot Showcase 5 06-02-2006 11:41
pic: Team 1501 Tranny Wayne Doenges Robot Showcase 8 19-02-2005 02:52
It's Back! 4-Speed Shift-On-The-Fly Tranny. New and Improved! Travis Covington Robot Showcase 16 16-02-2005 18:28
Team 968's technokat inspired 4 speed tranny Travis Covington Robot Showcase 12 01-03-2004 10:06
