Re: pic: Dimensions of the Trackball on the Overpass
did you make the 32" wide overpass on center of the pipes or on the edges?
cause my number don't line up exactly with yours. here are mine: http://www.chiefdelphi.com/forums/at...6&d=1199655203 |
I used
32" from center of the pipe to center of the pipe all the way around to form a square. .75in radius for the pipe from the 1-1/2 steel pipe. the 40" Trackball. I made half of the ball in the center of the square and made the arc tagent to the pipe and vertical with the center of the mid point and revolved the ball, then I created a sketch through the center, and projected the geometries of the ball and the bottum of the pipe, returned, and there you go. |
| Parameters [Dimensions] for the controls? | Crazy | Control System | 9 | 21-01-2005 22:23 |
| Dimensions of the Pits | xxlshortys | Regional Competitions | 1 | 15-01-2004 22:01 |
| the size of the shipping crate, the maximum dimensions?????????? | MASherry | General Forum | 5 | 13-01-2004 22:30 |
| Dimensions of the kit boxes | Jean McAuliffe | General Forum | 2 | 24-06-2003 00:40 |
| Does anyone happen to know the dimensions of the... | Ragin_Kage | Technical Discussion | 4 | 26-03-2002 18:33 |
