Go to Post Though, of course, if the old one you like is shot, then you can just beat your new one with a hammer until it works the way you want. - Kevin Sevcik [more]
Unread 07-01-2008, 08:54
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: pic: XBot Electronics Day 2
Originally Posted by Tytus Gerrish View Post
stop using blue and white wires. most of the inspectors will just give you greif
Inspectors should not "give you grief" for using blue and white wires as shown here. (Inspectors are volunteers and volunteers are at the event to help teams, not to give them grief.) Per <R54> blue is OK for common circuits and white is OK for 12V. However, the use of these colors is not very common in FIRST, so you should be prepared to show your inspector the rule in case he/she has not seen this before.
Originally Posted by 2008 FRC Manual, Section 8 The Robot, <R54>
All wires distributing power with a constant polarity (i.e., except for relay module, speed controller, or sensor outputs) shall be color-coded as follows:
• Use red, white, or brown wire for +12 Vdc and +5 Vdc connections.
• Use black or blue wire for common (-) connections.
Richard Wallace
since 2003
Unread 07-01-2008, 09:23
MrForbes MrForbes is offline
Might want to check the rules again, per <R50> "All circuit breaker distribution panels must be directly connected to the power distribution block", so that white wire from the Maxi Block to the other fuse block might need to be moved. This would require adding another red section to the power distribution block also.
Unread 07-01-2008, 10:04
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
We used blue and white last year with no problem at three events. I hope that doesn't change Have you seen/experienced any inconveniences with the alternate color wires?
Originally Posted by Chuck Glick View Post
Nice looking board there.
One question, the 90 degree connectors for the DB-9 cables (tether, radio, programming), where did you find those. Look very useful, thanks.
-Chuck
Here are the connectors. They are a bit heavy, but with how close everything ended up on the board, they will probably come in handy.
http://www.l-com.com/item.aspx?id=8656
Make sure you get the right "exit" so the connector is going the right way
Yeah, I think this was under discussion. The board was wired this way because of the functional convenience of it. Maybe the kids will strip an interior portion of the wire and have a single piece all the way through Adding the other wire will be trivial when necessary.
Unread 07-01-2008, 10:06
Might want to rereread <R50>....it's pretty obvious to me that the intent of the rule is that you connect each load wire directly to the PDB, not to any other device. "No intermediate connections are permitted".
Unread 07-01-2008, 11:00
Tytus Gerrish's Avatar
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
one of the reasons for that was That I was your Robot inspector at championship. i know its no big deal what color your wires are as long as you diferinate between + and -.
Having been a robot inspector. i've seen how the typical voulinteer inspector is generaly given an idea about how to inspect robots and then tries to go through the list to the best off their ability. and they tend to ruin a teams day when they don't pass you for somthing silly like that
Yes your absolutely right be ready with the rule in your hand.
Im not saying that inspectors should "give you grief" . im saying that you will have some that will
Unread 07-01-2008, 12:11
CraigHickman
On the topic of different colored electronics, why does FIRST give us the wrong color Anderson Connectors for our mainbattery plugs? Red signals 24v. Yellow is for 12v. Anyone happen to know?
Unread 07-01-2008, 12:16
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
It's a donation. It pretty much means we get what they are willing to give.
Unread 07-01-2008, 12:49
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Do you know which standard that comes from, because I'm not aware of any such convention? Anderson makes both red and yellow SB50 connectors designed for 6 AWG and rated for 600 V (for insulation purposes). Their datasheet doesn't suggest a colour code.
Unread 07-01-2008, 12:59
Fred Sayre's Avatar
AKA: Fred Sayre
FRC #0488 (xbot)
I was thinking the same thing. I couldn't find a list on the Anderson site, but there was a list here http://en.wikipedia.org/wiki/DC_connector that suggests that at least Anderson has their own color coding recommendations.
pic: XBot 2007 electronics panel Fred Sayre Electrical 31 14-02-2007 00:28
pic: Team 488 XBot updated electronics view 1 Fred Sayre Extra Discussion 8 04-02-2007 17:25
pic: Team XBot Mecanum Practice Chassis Fred Sayre Technical Discussion 28 22-11-2006 09:21
pic: Xbot vs. Cheesy Poofs, Round 2. Madison Robot Showcase 16 27-10-2006 00:18
pic: FRC 488 - XBot - Hex Madison Robot Showcase 5 21-02-2006 19:30
