Re: pic: XBot Electronics Day 2
Might want to check the rules again, per <R50> "All circuit breaker distribution panels must be directly connected to the power distribution block", so that white wire from the Maxi Block to the other fuse block might need to be moved. This would require adding another red section to the power distribution block also.
Have you seen/experienced any inconveniences with the alternate color wires?Quote:
http://www.l-com.com/item.aspx?id=8656 Make sure you get the right "exit" so the connector is going the right way ![]() Quote:
Adding the other wire will be trivial when necessary.Last edited by Fred Sayre : 07-01-2008 at 10:07. |
Might want to rereread <R50>....it's pretty obvious to me that the intent of the rule is that you connect each load wire directly to the PDB, not to any other device. "No intermediate connections are permitted".
Having been a robot inspector. i've seen how the typical voulinteer inspector is generaly given an idea about how to inspect robots and then tries to go through the list to the best off their ability. and they tend to ruin a teams day when they don't pass you for somthing silly like that Quote:
Im not saying that inspectors should "give you grief" . im saying that you will have some that will Last edited by Tytus Gerrish : 07-01-2008 at 11:06. |
On the topic of different colored electronics, why does FIRST give us the wrong color Anderson Connectors for our mainbattery plugs? Red signals 24v. Yellow is for 12v. Anyone happen to know?
It's a donation. It pretty much means we get what they are willing to give.
| pic: XBot 2007 electronics panel | Fred Sayre | Electrical | 31 | 14-02-2007 00:28 |
| pic: Team 488 XBot updated electronics view 1 | Fred Sayre | Extra Discussion | 8 | 04-02-2007 17:25 |
| pic: Team XBot Mecanum Practice Chassis | Fred Sayre | Technical Discussion | 28 | 22-11-2006 09:21 |
| pic: Xbot vs. Cheesy Poofs, Round 2. | Madison | Robot Showcase | 16 | 27-10-2006 00:18 |
| pic: FRC 488 - XBot - Hex | Madison | Robot Showcase | 5 | 21-02-2006 19:30 |
