Go to Post Or you can always say "we programmed it that way." - probizzle [more]
Unread 08-01-2008, 01:35
Re: Crab Drive HELP!!***
If you do decide to undertake a swerve/crab design make sure to spend a little extra time in the design process to build in a back up plan; Make you can switch the crab/swerve into just a normal 4WD in case it doesn't work out. This way you at least have a driving base in case of failure and won't be stuck with a completely disappointing season.
I'd say go for it if you have you have a reasonable amount of resources; you miss 100% of the shots you don't take.
Unread 08-01-2008, 19:27
CarpeNoctem's Avatar
CarpeNoctem CarpeNoctem is offline
Ranger
FRC #1057 (Blue Knights)
Team Role: Scout
CarpeNoctem is an unknown quantity at this point
Thumbs up Re: Crab Drive HELP!!***
My team had a crab drive system last year. It worked great and for the game this year it should be good for going around... you dont even have to turn.
But it probably would not be good for hurdling.. Its best use could most likely come from herding the ball around with it
When designing something completely fool-proof, we often underestimate the ingenuity of complete fools!
-Douglas Adams
Crab Drive nukelear1991 Programming 13 21-12-2007 18:02
HELP?!? with Omnidirectional/Crab Drive KMAC42 Technical Discussion 8 09-01-2007 21:34
Crab Drive Joe_Widen Technical Discussion 9 21-04-2006 21:50
Crab drive question Tazlikesrobots Technical Discussion 13 31-07-2005 20:51
Crab Drive Collin Fultz Technical Discussion 3 04-09-2002 16:35
