Go to Post If FIRST makes a field invisible to the audience, I will buy every team a dozen Krispy Kremes. - Chris is me [more]
Unread 08-01-2008, 16:30
falconmaster's Avatar
AKA: Ledge
FRC #0842 (Falcon Robotics)
Re: pic: laying out the robot
Originally Posted by Al Skierkiewicz View Post
Fredi,
If you swap the breaker panels and the speed controllers, you can use the motor wiring directly to the Victors and save some wire loss. If you put them in a row, then that will leave some room in the center for the breaker panels with the terminal block at the front and you will essentially eliminate close to 4 wire feet of loss. At 0.1 volt drop per wirefoot at 100 amps you can get a little more out of the drive system. Then you can put the battery in the front to use it as counter weight and wire to the main breaker on the outside of the robot next to the breaker panels. Cool
Thanks Al, will do.
Faridodin "Fredi" Lajvardi KD7WKD
how do u figure out the torque req'd to move a robot? Salik Syed Technical Discussion 11 03-11-2004 08:12
Check out Disney's New Robot - Lucky the Dinosaur! IMDWalrus Chit-Chat 1 25-08-2003 16:49
Image Discuss: Team 122 testing out the robot CD47-Bot Robot Showcase 14 25-02-2003 20:41
Robot motion after the time has run out. Randy Ai Rules/Strategy 1 06-01-2003 17:17
