Originally Posted by squirrel
I was not talking about the case...
There are no "cases" involved. The wheels behave the same always.
This would be the same as just rolling a normal wheel across the desk.
Rolling a wheel and powering a wheel are totally different. If you placed a keyed or hex shaft through the wheel and tried to turn it while pressing into the ground, you'd see the wheel would want to walk down the shaft. This is because the wheel produces a vector that isn't straight ahead, but at approximately 45*.
...they do NOT have the same efficiency going forward and sideways/diagonal.
This is correct, and I said as much in my previous post.
Ok, let's try changing tack. Assume the mecanum wheels
do put 100% of the power forward. We know the gearboxes can't output more than 100%, so there can't be any force sideways. Therefore, the robot
could not strafe sideways.
However, we know that the robot
can strafe sideways. Therefore our assumption is false and the wheels must be producing a sideways force all the time.
The mecanum wheels
do not put 100% of the power forward. They behave just like regular omnis at 45* angles. You get about 70% power by moving forward, reverse, left, or right.
