Go to Post Now, everyone knows that Oompaloompas are like bunnies in that they have an insatiable desire to multiply, and the same can be said with Michigan teams (with all due respect) which are currently multiplying and filling that hand-shaped democratic kingdom with their honorable number. - Eugenia Gabrielov [more]
Unread 09-01-2008, 12:34
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
Re: pic: Omni Design Trial
Though incredibly versatile, the standard Mecanum wheel has an unfortunate side effect which reduces its effeciency considerably. Its wide range of mobility is due to the fact that the peripheral rollers translate a portion of the motor force into a force perpendicular or at an angle to that produced by the motor. This means that are large portion of the force in one direction is lost through the translation into a resulting force by the rollers.
Losses of effeciency when traveling in a straight line are due to energy lost in a direction normal to that of travel through the peripheral rollers which bleed off available energy as they rotate.
From http://www.araa.asn.au/acra/acra2002...eter-Tlale.pdf
pic: vex omni drive 1902_Battery_SGT FIRST Tech Challenge 6 28-05-2006 17:55
Omni-Wheel Design fightoplankton Technical Discussion 7 08-01-2006 23:49
pic: Dual omni-wheel Richard Wallace Extra Discussion 17 05-12-2005 10:38
pic: Omni Idea Sachiel7 Extra Discussion 4 31-01-2005 12:46
pic: omni wheels CD47-Bot Robot Showcase 15 03-03-2004 20:10
