Go to Post "The purpose of computation is insight, not numbers." - Tom Ore [more]
Unread 09-01-2008, 13:12
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
Re: pic: Omni Design Trial
Originally Posted by squirrel View Post
In what way?
I'd like to know...really....
Thinking that mecanums perform the same as a solid wheel when traveling forwards and backwards is flawed. Motors can not be applying a force and simultaneously perform as if they were not applying that force.
If you draw a vector diagram for a mecanum wheel, you get a line going at an angle to the axis of rotation. The forward pointing vector is a component vector and is of less magnitude than the diagonal vector. Summing these forward vectors give you a lower magnitude then if you had standard wheels in which the entire vector is pointing in the forward direction.
pic: vex omni drive 1902_Battery_SGT FIRST Tech Challenge 6 28-05-2006 17:55
Omni-Wheel Design fightoplankton Technical Discussion 7 08-01-2006 23:49
pic: Dual omni-wheel Richard Wallace Extra Discussion 17 05-12-2005 10:38
pic: Omni Idea Sachiel7 Extra Discussion 4 31-01-2005 12:46
pic: omni wheels CD47-Bot Robot Showcase 15 03-03-2004 20:10
