#16
Re: pic: FRC488 Running Laps
How fast could you get your bot traveling fps(feet/second) or mps(meters/second)
ok better question, what is maximum out put in newtons(or joules can't remeber which is correct) or pounds/square inch or the motor you were using, if i could have the seral number (or the motor(s)) that would be fantastic. thnxs p.s. asking if you don't feel like answering... p.p.s. are you even answering Last edited by XXShadowXX : 09-01-2008 at 22:21. Reason: it was lame |
#17
the most powerful out of these, and thus most suited for drive train use, is the 2.5" cim. You can use up to four (4), and no more. A picture can be found in section 10, they where packed in the black tote. a speed vs. torque graph can be found, along with a table, in G.5.2 DC Motors (Guidelines, Tips & Good Practices). Watts under normal load is 205, according to the table. |
#18
there should be a nos button
#19
| pic: FRC488 - Operator Interface | Madison | Extra Discussion | 6 | 17-02-2007 04:45 |
| pic: FRC488 2007 Chassis | Madison | Extra Discussion | 16 | 22-01-2007 18:51 |
| pic: FRC488 -- Ball Shooter | Madison | Robot Showcase | 4 | 03-02-2006 23:12 |
| pic: FRC488 - Hopper Mechanism | Madison | Extra Discussion | 16 | 01-02-2006 13:11 |
| pic: FRC488 - Overview | Madison | Extra Discussion | 12 | 31-01-2006 13:16 |
